T-Top Gasket
Old Jun 22, 2007 | 10:54 PM
3 Vette Man's Avatar
3 Vette Man
Default T-Top Gasket
I am somewhat new here. Just purchased a real clean 81. The back was loaded with new parts, my luck! Anyway the car came with two sets of t-tops. One set was a replacement and somewhat newer and the original set whereby one is good and the other is really cracked. Anyway the car came with a set of new rubber gaskets for the t-tops. The gaskets need replacing on the good set. I looked at the older cracked set and see where there are three screws on one of the four sides and the other three sides attach with some notched pins. It also appears that the gaskets (on both sets) are put down with adhesive. Can some one of you nice people tell me how to install, point me to a thread, or give some advice. Thanks and if I need to post this somewhere else, I will do so.
From St. Louis,
Thanks.
Old Jun 23, 2007 | 05:44 AM
RunningMan373's Avatar
RunningMan373
your lucky. I just did mine Wednesday. 3 hour job. Go buy some weather stripping adhesive. That's what it's called. They got it at Napa, in the isle with the RTV. One tube will do you. There called T-top weatherstripping btw.
Get a large cleared flat table and a large towel and many large rags, a butter knife, 2- 12oz bottles of the 91% or higher alcohol from the super or a drug store, Some blue painters tape, some duct tape, a washed green scotch scrub pad, a set of standard pliers and 3 sheep. OK, scratch the sheep, but you'll need everything else.
Get the T-Tops, get one and put it on the towel, on the table. Next, roll the weather stripping with your finger tips with hard pressure, both hands, to break the seal between the T-Top, Stripping and Glue, all the way around the T-Top. Every 3" or so there are these little palstic pins. Pull the stripping loose while leaving them in is ok, but try not to break off any of the heads on them. Use the butter knife as needed to pry between the stripping and top, and try to pull the stripping off as much as you can. You want to leave just the glue residue and pins. That's for the center, front and back.
On the outside, there is a channel. Remove the stripping from the outside channel ignoring the screws if you can.. Now, with all the stripping removed, use the pliers to remove the little plastic pins. Don't break them off as if you do, they will rattle around inside the top forever.
Next use the butter knife and a rag soaked in alcohol to clean the channel. USE EXTREEM CARE around the 90+ % alcohol. It is highly flamable,, burns yellow and hot and fast,, not blue and cold like the 70% stuff. Treat it like gasoline. I burns like it. don't ask me how I know, just keep a fire extigusher handy and be happy.
Next, take the scotch pad and buff out the rest of the area where the old stripping was, attempting to get out most of the glue, or sand the glue flat with no or minimal corners sticking up. Pay special attention to the horozontle channels, ~ 1/8" on the outside line. These MUST be free of all old glue and weather stripping. when done, use a alcohol soaked! rag to clean the area where the new weather stripping will attatched.
The hardest part of the install is to get the channel side of the new stripping to lay flat on the outside corners. That's what the tapes for. Test fit the weather stripping peice w/o any glue or installing any push pins, just test fit it in the outside channel. See where it doesn't want to conform to the bends. It must attatched correctly, or it is a waste of time.
Take note: The Glue drys FAST!!!,, 3 mins tops! lay down a thin bead of glue down the middle of the outside leg, the channel w/o the pins, and about 3" down both front and back faces. Install the weather stripping peice by moving it in directly opposed to the channel, and over press it in to the outside 1/8" channel so it sits completely in both channels, and set the pins into the front and back up to the glue. Now tape down the outside stripping as needed to ensure it dries flat. Use care here, this is a very important step. Now lay a bead around the other 3 faces, you don't really need that much, and install all the push pins on the new stripping. Let dry for 2 hours in the sun and your good to go. Chris.
Old Jun 23, 2007 | 08:02 AM
3 Vette Man
Chris,
Thank you. One more question. You say to ignore the three screws, but they are screwed into holes in the rubber???? Do they come out at all?
Thanks.
Old Jun 23, 2007 | 04:13 PM
RunningMan373
The rubber has little slits, If you take them out and screw them back in through the stripping, they just bypass and push the rubber out of the way anyway. install over them. fill up around the head of the screws with adhesive, but don't over do it. You can use 1 as a position locator if you need to.That being said, mine is a '73 and yours is an '81, and I know they some what changed the T-Top design along the way, so if you have large screws, or deep ones through the rubber, do what you need to, to get it to work, common sense. My method works, well. I just finished the rest of the weather stripping on the car, yeaterday too. Really not that hard. I used the same method and tools I pointed out above. Not really that hard. The T-Tops were by far, the hardest.
Old Jun 23, 2007 | 08:39 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Late 77 and later has the metal retainer molded inside the rubber on the door window side.
Old Jun 23, 2007 | 08:45 PM
a1sensei's Avatar
a1sensei
It really does not matter because you are going to get wet anyway! (not that I'm bitter or anything.) God bless, Sensei
Old Jun 24, 2007 | 07:36 AM
kb2fzq's Avatar
kb2fzq
Yup...went thru the whole ordeal as well and "still got wet"
Being mine is a (clear weather) weekend driver only and not garaged, I've resorted to watching the weather man and if rains a comin' I plastic trap the roof and close the doors on the tarp...bandaid?...yup, but the inside stays dry..
Old Jun 24, 2007 | 04:25 PM
RunningMan373
I keep mine under a cover. Some are available for under 100. not as good as a garrage, but better then the elements on it.
Old Jun 24, 2007 | 11:05 PM
Waltski's Avatar
Waltski
Cruising
Thanks for the info... Good stuff.
I'm going to do my t-tops at the end of the Summer.
Old Jun 24, 2007 | 11:26 PM
l1dws's Avatar
l1dws
Runningman 373 where did you buy the rubber for the T tops
Old Jun 25, 2007 | 12:29 AM
RunningMan373
These guys. http://www.cssbinc.com/ The T-top weather stripping they got is the best I've seen, really first class quality. The stuff I have pictured isn't near as good, it's for the front window uppers, it's OK but the T-top stuff they got is first class. diff manufacturer.
Looks like they got some pretty good prices on brake kits too.. to bad I just did mine. Nothings more fun then getting a heavy box from UPS.
Old Jun 25, 2007 | 09:21 AM
l1dws's Avatar
l1dws
Runningman373 Thanks for the info....I see that you live in Concord....so do I......
Old Jun 25, 2007 | 04:16 PM
RunningMan373
Yea, we should have a get together some time with all the members who live here in the extended bay area. That would be quite a car show in it self. Keep your ears on about it, I will too. C.
Old Mar 17, 2008 | 10:42 PM
DP77Vette's Avatar
DP77Vette
St. Jude Donor '10
OK, next question. When you install the top back on the car, how do you keep the rubber from rolling up at the T-bar???
Screwed up one side already!
Thanks!
Old Mar 18, 2008 | 03:29 AM
RunningMan373
Thanks!
OK, once it's dry and installed it's in it's finsished location, and it should sit correctly. If it's good quality w/s, it should seat correctly. I simply pushed my T-top in at the highest angle I can and push it down and latch it. good luck,,C.
To T-Top Gasket
