81 rear rotors
Old Jun 22, 2007 | 11:26 PM
sjmaster's Avatar
sjmaster
Default 81 rear rotors
OK...I am pretty sure I know how....but thought I would ask first. What is best way to remove rear rotors. I have two shop manuals.....and neither says how....it just says remove rotors....and mentions drilling rivits, which are already gone on mine, but not a word more.
Old Jun 23, 2007 | 04:47 AM
RunningMan373's Avatar
RunningMan373
It's easy. Just be aware of the rear brake shoes might catch, and you may need to adjust the star bolt. easy.
Old Jun 23, 2007 | 04:55 AM
woodlandcorvette's Avatar
woodlandcorvette
If the rivits are already gone then rotor should slip off after you take caliper off away from rotor. If rivits are there you have to drill them out and thats a pain I thought but didnt take long. Good luck
Old Jun 25, 2007 | 02:48 AM
gingerbreadman1977's Avatar
gingerbreadman1977
thats right . if the rivets are gone than yes it should just slide staright off once your brake caliper is removed.
Old Jun 25, 2007 | 10:43 AM
UKPaul's Avatar
UKPaul
... and if the emergency brake shoes aren't catching inside! Make sure you mark the rotor & hub so that it can be fitted back in the same relative position. If you're fitting new rotors then I recommend getting a dti & shimming them to get runout within specs.
Old Jun 25, 2007 | 10:55 AM
guitarcrazy02's Avatar
guitarcrazy02
good remedy for stubborn rivets = air chisel. I had to deal with them on my front end when I replaced my ball joints. Be patient and they'll come off.
To 81 rear rotors
