Newbie question : Bird cage
Old Jun 23, 2007 | 11:24 PM
pat80's Avatar
pat80
Default Newbie question : Bird cage
I just want to know, if the bird cage is rusted, can we change it or repair it? Because, my door seen to be a little down, so I think the bird cage is rusted.. can I repair it.
Old Jun 23, 2007 | 11:47 PM
mdj21's Avatar
mdj21
a saggy door could just be worn out bushings on your door hinges or hinges that have slipped.
check the easy things first before you jump into the worst case.
Old Jun 24, 2007 | 03:27 AM
Belgian1979vette's Avatar
Belgian1979vette
A birdcage is not easy to check when everything is assembled. Easiest way is to disassemble the kick panels and take a look behind. Tell tale signs are also rust on the outside of the A-pillar.
Be ware of birdcage rust. It is not an easy to fix problem if (a big if) you got them.
I had it on my car and only discovered after windscreen removal. Went as far as to do a birdcage transplant. Can be done if you know what to do, but a lott of hassle and not for a novice mechanic.
Succes
Old Jun 24, 2007 | 07:13 AM
RunningMan373's Avatar
RunningMan373
Good pictures of the Cage here, plus what to look for. It's repairable. alot of the guys here are really skilled and have fixed thier own. Some have had thiers fixed be Experienced Shops. $ really depends on the sevrity of the rust. If it's confined to the upper windshield and firewall braces, I'd venture a geuss of about 700 to 2500.
http://geocities.com/dilbertopotimus/index.html
To Newbie question : Bird cage
