computer
they all work and have thier own characteristics. thanx
You can dump the computer, but be aware of what else will need attention: TCC and SMOG components if you need to deal with that.
The 82 Cross-Fire injection system is actually a pretty good design, it just needs some tweaking. The manifold was based off of the late 60s Camaro 302 crossram.
A couple of questions:
We stopped in at a Vette shop near Brisbane & the guys there said that you had to have right hand drive after a certain year. Is that still the case?
What ya gonna do with the computer? If you are going to chuck it out can I give you a few tinnies for it? You wouldn't need to worry about posting it to the UK, just to Stanthorpe, QL.
sure if i do lose the computer ill send it to good old stanthorp(freezing)for ya!! a carton of corona should cover it !
cant wait to get rid of this ugly exhaust but it will be the final piece in the puzzle.
Just let me know if you're going to junk it & I'll sort out a carton of corona
And Stanthorp is freezing, it's colder than here!!!What I did with my '81 was to finish off the removal of the emissions control stuff (a few bits were left hanging, vac leaks, etc), fixed the bent "dancing needle" in the carb & found that it ran pretty well, also giving good fuel economy. So I figured that as the computer was working then it would be stupid to remove it for no reason, other than spending a wedge of cash getting a new carb & dizzy. A wild cam (that would drop vacuum down to the point that the computer would freak) isn't n option as I can't afford the fuel economy that would result; I do fairly long runs & with fuel at about $9/gallon it'd get painful pretty quick.
Changing the stock exhaust for true duals (2 1/2") was the best mod I ever did for performance, the engine actually felt alive & responsive afterwards. But I found that the power dropped off higher up the rev range, like it was being strangled, & it turned out to be due to the restrictive manifolds. I then fitted Dynomax ceramic coated headers & made up a new exhaust, rather than buggering about cutting & welding up the Mid America true duals that were on it. This is worth considering if you want to modify the exhaust. As I had just fitted a BTO 200-4r OD trans (THE BEST mod I've done to it
), I had an x-member with clearance for exhaust pipes on both sides, so I could run a pipe down each side of the car. With a stock x-member you can cut a scallop (curved chunk) out of the drivers side of it & then weld a metal plate over it so that it has clearance for an exhaust just like the passenger side does. Then get an exhaust shop to supply some 2 1/2" stainless pipe. All you need are 4 bends done in the entire system, two for each side. You'll need a 15* bend just behind the headers so that the exhaust runs parallel to the underside of the car (the headers point down slightly) & then an 85* bend at the rear so that it kicks out to the mufflers like the original. I did mine in sections, expanding the ends of some parts to give a slip fit. This allows a bit of jiggling into position so that you can get it all lined up. Here's a pic (mess due to an oil leak!):
The lowest part of the system is just below the drivers floor & gives 3" of ground clearance. If you do fit dual pipes then I'd recommend fitting an H/X pipe as it gives a much better idle & exhaust tone than separate pipes. And if you've got an oil leak, don't bother polishing the pipes before fitting them
The computer controles that stuff, so you can't get rid of one without the other(or finding a solution). As for calling it EFI, yeah I know it technicly is not, I just brain farted calling it that
, but it is basicly an electronicly controled carb, just not injected,
