hydraulic lifters
Old Jun 24, 2007 | 01:25 PM
rick1500's Avatar
rick1500
Default hydraulic lifters
I misinterpreted the directions on setting the tappets for my hydraulic lifters. It said to tighten down the rockers until the pushrod could barely turn, then 1/2 turn more. So, I did't realize I was compressing the lifters just about completely (since I was still able to turn them if I didn't), then adding a 1/2 turn. I later realized that I'm supposed to just tighten them down just so all the slack was out and the lifter was just about to start to compress, then add the 1/2 turn. I backed them all out and did it the right way.
My question is, did I damage anything when I had them completely compressed plus the 1/2 turn? Everything seems OK now, but I just want to be sure. Thanks,
Rick
Old Jun 24, 2007 | 02:05 PM
SteveG75's Avatar
SteveG75
If you didn't bend a pushrod, then you should be OK.
Old Jun 24, 2007 | 03:37 PM
rick1500's Avatar
rick1500
Thanks Steve. I think I'm OK then. I'll go ahead and put the valve covers on.
To hydraulic lifters
