69 Caliper problem
Old Jun 24, 2007 | 09:52 PM
JAMES69's Avatar
JAMES69
Default 69 Caliper problem
My caliper (RF) siezed on my 69 last week. I am in the process of replacing it, but one othe retaining bolts will not come loose to get the old caliper off. I've tried 10W40, propane torch, to no avail. Anybody have any suggestions?
thanks in advance,
Jim
Old Jun 24, 2007 | 10:01 PM
...Roger...'s Avatar
...Roger...
More heat and an impact
Old Jun 24, 2007 | 10:19 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Did you try a 2ft. breaker bar? If so, stick a piece of pipe on the end of said breaker bar.
Old Jun 24, 2007 | 10:24 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
uh, yea. that was helpful bat dude.....
i've used anti sieze, an end wrench, and a hammer to beat/get 'em of before..
Old Jun 24, 2007 | 11:18 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Umm...that's how I've removed stuck brake bolts before...
Old Jun 25, 2007 | 02:25 AM
wombvette's Avatar
wombvette
Impact wrench and a good six point socket.
Old Jun 25, 2007 | 11:08 PM
JAMES69's Avatar
JAMES69
Default caliper bolt
Thanks, Im off to buy some impact wrench sockets to give it a try.
Jim
Old Jun 25, 2007 | 11:40 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Jim
A good set of impact sockets is a must (even if you use them on a regular wrench). I've shattered the regular 12pt. chrome sockets before...
Old Jun 26, 2007 | 05:40 PM
BB68Vett's Avatar
BB68Vett
Also, make sure you are wrenching on the caliper mounting bolts and not the large bolts that hold the caliper halves together. The caliper mounting bolts are a 5/8" hex, I believe.
Old Jun 26, 2007 | 09:00 PM
w1ctc's Avatar
w1ctc
WD40 is not very good for rusted bolts. Soak in PB Blaster overnight and try again.
To 69 Caliper problem
