Lifter noise
Old Jun 25, 2007 | 01:47 AM
jake1's Avatar
jake1
Default Lifter noise
What can I do to check this out. I have a 71 350/270hp that has always ran like a top, but the last cruise I noticed a metal ticking noise that rises and lowers with rpms. It's coming from pass side valve cover. Just changed oil and added a engine cleaner (stop valve noise type) but it's still there. How can I narrrow this down. Thanks.
Old Jun 25, 2007 | 02:19 AM
ltlevil's Avatar
ltlevil
Just a thought but you can pull the valve cover and check the rocker arms-you will need torotate the motor in order to check all of them. If you find one that is loose I would look further for the root cause. This may not be the problem but it is a suggestion.
ltlevil
Old Jun 25, 2007 | 07:45 AM
Trae1976's Avatar
Trae1976
Are you positive its a lifter? If you notice it more under load or at high RPMs, first check the exhaust manifold / header bolts - could just be an exhaust leak.
Good luck.
Old Jun 25, 2007 | 07:59 AM
HP Hunter's Avatar
HP Hunter
Default Tapping noise
Probably got yourself a bad fuel pump. Wouldnt be a first?
Harry P.Hunter
To Lifter noise
