Loose rear brake caliper bracket
Old Jun 25, 2007 | 09:24 AM
theandies's Avatar
theandies
Default Loose rear brake caliper bracket
I replaced all 4 calipers last weekend and found that my right rear caliper bracket is slightly loose in the back a forth movement, like spinning the tire. I looked a a diagram and it looks as if I'll have to remove the parking brake shoes to get to the bolts to tighten them up. Is this correct or do I have to rip the t-arm off?
Old Jun 25, 2007 | 09:45 AM
SIXFOOTER's Avatar
SIXFOOTER
you can do that with the T-Arm in place
Old Jun 25, 2007 | 10:11 AM
theandies's Avatar
theandies
Old Jun 25, 2007 | 12:07 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
You might be able to get to those nuts through the star wheel adjuster hole in the hub.
Old Jun 25, 2007 | 12:18 PM
theandies's Avatar
theandies
Thanks BM I am going to try every way possible to do this without taking the parking brake shoes off. I really hate messing with drum brakes, especially ity-bity drum brakes.
Old Jun 25, 2007 | 04:46 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I'm not positive, but it seems like that hole is in about the right spot to get to the studs, when rotated appropriately.
I locktited the crap out of mine when I rebuilt the T/As - I really, really don't want to worry about that stuff coming apart.
Old Jun 26, 2007 | 09:13 AM
theandies's Avatar
theandies
Update:
I took the parking brake shoes off and the nuts were right there. There was no way going through any of the holes in the hub or rotor since the nuts are 9/16th. 3 of the nuts were loose but not to the point where you could take them off by hand. One was finger tight. I removed the nuts one at a time and put max strength lock-tite on them. I also found some acorn style lock nuts and put them on. Everything is A-OK. Brakes are done and I am back on the road!
Thanks everyone
To Loose rear brake caliper bracket
