'94 4L60E questions
Old Jun 25, 2007 | 01:36 PM
AkXb70's Avatar
AkXb70
Default '94 4L60E questions
I have a friend with a totaled '94 C1500. Hes parting it out and wanted to know if I wanted the engine/transmission out of it. Now I have a freshly rebuilt 350 and 350 trans, but I'm dieing to get an overdrive gear. If I remember correctly the 94's had some of the first 4L60E transmissions. So heres my questions:
1. It should fit just like a 700R4, correct? I'll need a shorter driveshaft and a different crossmember (I drive a '79)
2. Can I take the mechanical speedo housing off of a 700R4 to put in place of the 4L60E's tailhousing?
3. How much torque will these early models take? the later years didnt seem to have any trouble with the 375-400ft/lbs of torque LS1's and LS2's put out, but the engine in front of this tranny only puts out about 300 or so.
4. A computer control kit should be able to take care of lock up functions and throttle position sensors on my carburated engine, correct?
I was dead set on doing a 2004R swap, but I like the idea of computer controlled shift points instead of vacuum controled and this may end up being cheaper as well. Thanks in advance guys.
Old Jun 25, 2007 | 01:43 PM
palamesa's Avatar
palamesa
LS1TECH.com has an excellent section on transmission swaps. That's a good place to start.....gp
Pete K's Avatar
Pete K
1) Correct
2)No. speedo sensor stays, but I think the electronic kit allows for this
3) It depends. The 94's use a single cage sprag that sometimes fails at, or slightly before 400 hp. High mile units flip the spags very easily
4) Correct. Kit runs $600 or so.
Old Jun 25, 2007 | 10:04 PM
hap1971's Avatar
hap1971
Strictly an opinion based on observations --
I work/own a 'junkyard' and we sell replacement more 93,94, and 95 model 4L60s than all the other years combined, twice over.
Just like anything else, the first years of something are likely to be more susceptible to design flaws. Also, the trannys have slightly different pin arrangements on the big plug than the later models, if I remember correctly. I would think an actually 700r4 would be a lot easier, more dependable swap. You can put it in even without a controller for the lockout, and still have an overdrive. The kickdown cable can be fitted to a carb also. I like simple! If you are going to do a 4L60, get a 96 and up model.
Old Jun 26, 2007 | 11:06 AM
AkXb70's Avatar
AkXb70
Well, I guess its for the better then. I got home yesterday to find out he had already sold it off. For vacuum controlled trannies, I think I'll be sticking to the 2004R (for the simplicity of the install) unless someone can convice me a new 4L60E is worth an extra $1,200. I really like the idea of programmable shift points, but thats a good bit to pay for it.
To '94 4L60E questions
