Break-In Additives
Old Jun 25, 2007 | 01:43 PM
Ed Blue 03's Avatar
Ed Blue 03
Default Break-In Additives
Have the original 30W oil with break-in additives my 73-350 engine, it's been months. Took a while to get it running, so most of the time running was idling. Drove it around a little this past weekend. Should I keep the current oil with additives in there until I drive it some more? What are the pluses and minuses?
Old Jun 25, 2007 | 02:46 PM
karioth's Avatar
karioth
if its a fresh rebuild or new motor i would change the oil once after 500, again after 1000 (1500 total), and then regularly afterwards. i'm not familiar with break-in additives, ive always just used regular dino oil
Old Jun 25, 2007 | 02:57 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Rotella 15W40 is non detergent and has zinc in it and is probably the best break in oil there is.. That's what I use on my race engines for break in!
Old Jun 25, 2007 | 03:29 PM
bashcraft's Avatar
bashcraft
I just changed the oil in my new motor. I ran it in the garage for a couple hours then drove it 3-4 miles. Then I changed it. It was pretty black, but my carb was running real rich at first so I think I had some gas in the oil.
Old Jun 25, 2007 | 03:37 PM
ACECO's Avatar
ACECO
St. Jude Donor '04 & '05
This is more of a question than a reply but depending upon the responses it may be useful for you. I've "heard" that STP oil additive has a good amount of zinc in it and some use this as a supplement to todays standard low zinc oil. Can anyone verify this?
TIA!
Old Jun 25, 2007 | 03:42 PM
Scott Marzahl's Avatar
Scott Marzahl
Can't comment on the STP, but if you want an oil additive for Zinc then a few ounces of GM Engine Oil Supplement (EOS) for new engine break-in is probably the best thing out there.
Old Jun 25, 2007 | 03:56 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Olivier,
I've read that Rotella (old formula) is the way to go on break in, but why the thick grade? No arguing, I just wouldn't have thought to do so and I'm about to break in my new 400 so I'm very interested.
Old Jun 25, 2007 | 04:03 PM
Ed Blue 03's Avatar
Ed Blue 03
I added a bottle of Crane break-in additive, plus all the lube I put on the cam and rockers when assembling it. Sounds like it’s time to get that crap out of the engine. The engine has a 70 LT1 solid lifter cam, plan on using Castrol GTX 20-50. It’s Zinc numbers are almost as good as Rotella.
Old Jun 25, 2007 | 04:21 PM
Scott Marzahl
Rotella 15W-40 is what I use as a regular oil on my older (pre-roller lifter) cars. Actually it is the recommended oil by BMW for their V-12s engines too.
Old Jun 25, 2007 | 07:17 PM
GrandSportC3
Originally Posted by CA-Legal-Vette
Olivier,
My engine builder builds tons of circle track and drag engines and I trust his suggestions. I assume that the thicker grade is used for bearing protection..
Old Jun 25, 2007 | 07:18 PM
GrandSportC3
Rotella is great stuff but can't be used with vehicles with catalytic converters as the zinc can't be used with those..
Old Jun 25, 2007 | 07:46 PM
RMS73's Avatar
RMS73
Info from the Shell Answer Man about the wear additives in Rotella the old CI-4 verus the new CJ-4 spec's.
He, actually a she, said
...........................CI-4..............CJ-4
Zinc.................. 1390 ppm.......1210 ppm
Phospherous.........1265 ppm.......1110 ppm
About 12% lower for the new oil, but much more than the regular car SM spec oil.
Roger
Old Jun 26, 2007 | 07:56 AM
Roughrider's Avatar
Roughrider
I've been told by the counter guy at a local Chevy dealer that the GM Engine Oil Supplement (EOS) is simply GM's version of STP. I don't know how accurate that is, and he does have a vested interest in selling GM products, but it's his story and he's sticking to it.
Old Jun 26, 2007 | 08:22 AM
Edzred72's Avatar
Edzred72
My machinist said the same thing. Told me to run straight 40W on the new motor for a few thousand miles before switching to a multi-grade.
Eddie
Old Jun 27, 2007 | 09:56 PM
glen242's Avatar
glen242
Did not realize there was ANY multi-viscosity oil that was Non-Detergent. Shell does not mention it on their web site.
Old Jun 27, 2007 | 10:24 PM
Dick Whittington's Avatar
Dick Whittington
Shell Rotella IS a detergent oil.
GM EOS has anti scuff additives. Use it for the first 500 miles and then change oil.
Old Jun 28, 2007 | 12:44 AM
ltlevil's Avatar
ltlevil
That's also the oil Crane or CC (forget which) recommended in a tech bulletin they sent out awhile back. Apparently this was mainly based on the zinc content.
ltlevil
Old Jun 28, 2007 | 08:34 AM
Trae1976's Avatar
Trae1976
From Comp Cams' website:
http://www.compcams.com/Community/Ar...ID=-1578676008
To Break-In Additives
