Speedometer Whoa's.......
Old Jun 25, 2007 | 07:41 PM
1972vettman's Avatar
1972vettman
Default Speedometer Whoa's.......
The speedometer on my 72 is about 15 mph off!
Now the rest of the story, i recently installed a Richmond 3.70 gear and am aware that the speedo cable gear must also be replaced but i'm not sure where to start! Call the local Chevy dealer and they were clueless! Is there a formula or known conversion where the speedo gear teeth added or subrtracted equals so many mph increase or decrease? If so, which is it, add teeth = mph gain or subtract teeth = mph gain? Someone please help!!!!!!!
Old Jun 25, 2007 | 08:13 PM
nealkeith's Avatar
nealkeith
Default Speedo Off
There's a guy up in Flint Michigan that may be able to help you, I will look up my history on my browser to see if I can get you his number. You can only change the external gear so much. If that doesn't get close enough he builds a small gear box that goes inline for the fix. Try www.specmo.com
Regards, Neal
Old Jun 25, 2007 | 08:51 PM
nealkeith's Avatar
nealkeith
Default Speedo Off
The forum store on this site sells the gears. More teeth shows less speed, less teeth more speed.
Regards,
Old Jun 25, 2007 | 08:59 PM
bozzman3's Avatar
bozzman3
Pull out your gear and see what you have.Then start going up in tooth count.2 teeth equals about 3mph to 5 mph
Old Jun 25, 2007 | 09:45 PM
1972vettman
Regards,
Being 15mph high on the speedo, i would then need a gear with 10 more teeth if 2 teeth is equal to 3 - 5 mph, correct?
Old Jun 26, 2007 | 07:34 PM
C3 Stroker's Avatar
C3 Stroker
......approximately correct. BTW, do you have an auto or manual trans? (The gears are different). Here's a link to follow to help you calculate:
http://www.tciauto.com/Products/Tech...eedo_gears.asp
Old Jun 26, 2007 | 08:20 PM
1972vettman
i have an automatic
Old Jun 26, 2007 | 09:51 PM
Jc3vette's Avatar
Jc3vette
Note: If your speedometer reads too high, a driven gear with one more tooth will slow it down approximately 5 MPH. This is from Corvette Central and it works for the factory four speeds, My book says a 42 tooth gear for a 3.70 with a automatic factory trans. What gear how many teeth are you running now?
Old Jun 27, 2007 | 07:55 PM
C3 Stroker's Avatar
C3 Stroker
Your numbers look good......I'm running a 45 tooth with my 4.11 auto and used a 43 tooth when I had 3.90's......this is with the factory 15 tooth drive gear in the tranny.
Old Jun 27, 2007 | 08:20 PM
Duke94's Avatar
Duke94
72' 4-speed with a 3.70 gear should use a 22 tooth gear.
Old Aug 7, 2007 | 11:34 PM
lr172's Avatar
lr172
I am trying to find the right gear for a my 4 speed in my '75. I have the 3.70 rear end, but the prior owner never changed the gear. The document above references a 22 tooth gear for the '72, but it appears that a 20 tooth gear is specified for the '73 & '74. Do you know which is used for the '75?
Thanks for an assistance you can provide.
Old Aug 8, 2007 | 06:05 PM
Duke94's Avatar
Duke94
Here's the 75' 4 speed chart.
Old Aug 9, 2007 | 01:39 AM
lr172's Avatar
lr172
Thanks for the help. I appreciate it!
Old Aug 9, 2007 | 01:02 PM
MN81C3's Avatar
MN81C3
I changed my ratio from 2.87 to 3.36 with a t350 automatic. Any idea what gear i should use? I am about 5 mph high at 55.
Old Aug 15, 2007 | 01:22 AM
lr172's Avatar
lr172
I pulled the speedo cable off the 4 speed and the color the gear was blue, as indicated in your chart. However, I passed an automatic radar station and I my indicated speed was about 7-8 MPH over the radar. The previous owner told me it was changed to a 3.70, but I have confirmed yet.
Can anyone give me a recommendation for a gear that will offestt this 7-8 MPH overage I am experiencing.
Thanks for the assistance here.
To Speedometer Whoa's.......
