real quick alternator question
Old Jun 26, 2007 | 01:53 PM
guitarcrazy02's Avatar
guitarcrazy02
Default real quick alternator question
I have a radio noise suppressor that splices into the alternator main power line. There are two hot lines coming from my alternator. I don't know which one is the main line to the battery. Any help would really be great.
Old Jun 26, 2007 | 01:55 PM
IrishJoker's Avatar
IrishJoker
The one with the BLACK Plug cover goes to the Battery.
Old Jun 26, 2007 | 01:56 PM
HO-alts-Rick's Avatar
HO-alts-Rick
Old Jun 26, 2007 | 02:43 PM
guitarcrazy02
Thanks a lot. Just out of curiosity, what's the other plug for?
Old Jun 26, 2007 | 02:51 PM
SIXFOOTER's Avatar
SIXFOOTER
Thats the Exciter and voltage sense wires. The exciter turns the alternator on and the sense wire detects what the system voltage is ans uses that to determine alternator output
Old Jun 26, 2007 | 03:14 PM
guitarcrazy02
Man I love this forum. Someone somewhere knows anything you could possibly want to know.
Old Jun 26, 2007 | 04:31 PM
Durango_Boy's Avatar
Durango_Boy
That RFI suppressor will work better if installed inline of the radio's power wire.
Old Jun 26, 2007 | 07:53 PM
HO-alts-Rick
Your alternator already has a capacitor in it for filtering "noise" by putting it in the radio wire it will help suppress any "noise" from other sources.
Old Jun 26, 2007 | 08:35 PM
mrvette's Avatar
mrvette
Yes, that internal cap does knock some of the sharpest spikes off the diode cutoffs...., but it is no panacea....
More expensive amps will not pick up the alt noise....cheeep crap will....complicated issue, not easily explained....
Old Jun 28, 2007 | 09:46 AM
New's Avatar
New
Can you help me!!
I have sb -71 Vette. My alt comes two wires, brown and black/white. Now i wonder which goes where? The alt is marked R1 and 2. Where the brown goes in and what about bl/wh?
Old Jun 28, 2007 | 10:02 AM
mrvette's Avatar
mrvette
I forget the orginal GM color codes...but you take a voltmeter, and check which one is hot with key off, that one goes to the MOST clockwise pin when viewed from the back of the alt....many alts have lost their markings, so that is why I referr to MOST CLOCKWISE or least clockwise....
the other wire should have NO voltage on it, turn on the key, don't bother starting the car....the wire should then have voltage on it...if so, that goes to the LEAST clockwise terminal in that connector...
Old Jun 28, 2007 | 11:04 AM
New's Avatar
New
Thanks a lot mrvette!!
To real quick alternator question
