Replacement seatbelts?
Old Jun 27, 2007 | 11:54 PM
vetteflsurfer's Avatar
vetteflsurfer
Default Replacement seatbelts?
I am restoring a 1976 Corvette. Lowering the floorpans to accomodate my 6'4" frame with the new C5 z06 seats I am installing and the old seatbelts were trashed. Looking for an economical and effective replacement for seatbelts. If anyone has any reccomendations I would appreciate it.
I am atleast a shoulder and lap belt.
Old Jun 28, 2007 | 01:28 AM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
there are several universal sets out there. i picked up a set of 4 points for about $150. i dont remember the vender but i did a search and found them that way.
Old Jun 28, 2007 | 01:34 AM
Secret Squirrel's Avatar
Secret Squirrel
http://www.julianos.com/seat_belts.html
http://www.andoauto.com/seat_belts1.htm
Old Jun 28, 2007 | 01:58 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Use the "Search!" sticky to get into the archives, and search for "camaro" or "f-body" seat belts.
Old Jun 28, 2007 | 05:27 AM
RunningMan373's Avatar
RunningMan373
I got a set coming from Andover. they stock the Black, but have to get any colors custom built, mine are finally in transit. It's a good day. good original fit style belts, right colors and dimensions. Stay away from Ecklers anything with seat belts! The so called replacement doesn't fit worth a da*n and the direcect replacement set is over 500 bucks. joke on that. 500 bucks for a set of replacement black seat belts.
http://www.andoauto.com/Corvette1.htm
Old Jun 28, 2007 | 09:49 AM
wjsullivan's Avatar
wjsullivan
You could always hav Ssnake-Oyl reweb the existing ones to be longer.
Old Jun 28, 2007 | 11:33 AM
rfhall50's Avatar
rfhall50
Try GotBelts.com
They have a buch of diffrent colors and all the pieces. Just ordered several samples for my '80.
Bob
Old Jun 28, 2007 | 01:29 PM
johnwhoss's Avatar
johnwhoss
I'm very happy with the replacement belts I got from Mid America. Easy to install and they fit fine. $299 complete for both sides.
Old Jun 28, 2007 | 07:02 PM
redwingvette's Avatar
redwingvette
I used the F-body belts. There are lnger then the originals and work great.
interior
Old Jun 28, 2007 | 07:24 PM
JustinGJ's Avatar
JustinGJ
Used '02 Trans Am belts for my '76, you need the rear belts out of a coupe. Flatten one little tab on the rear mount behind you, hog out the holes a tiny bit for the slightly larger mounting bolts, and you're set.
To Replacement seatbelts?
