I Have a voodoo Hydraulic flat tappet cam and I bought this fuel pump push rod with bronze tips. Seen Below. I have heard that this is for roler cam cores. Will it work with my cam???
CCA-4607
Brand: COMP Cams
Product Line: COMP Cams Fuel Pump Pushrods
Part Type: Fuel Pump Pushrods
Fuel Pump Pushrod Material: Chromemoly
Fuel Pump Pushrod Tip Material: Bronze
Lightweight: Yes
Diameter (in): 0.500 in.
Length (in): 5.750 in.
Quantity: Sold individually.
Fuel Pump Pushrod, Chromemoly, Bronze Tip, Chevy, Big/Small Block, Each
