69 Brake Rotor Removal
Old Jun 29, 2007 | 08:35 AM
FLYNRYN's Avatar
FLYNRYN
Default 69 Brake Rotor Removal
Hmmm....
My front rotors appear to have the stack rivets holding them in place, but Im nearly positive that they have been removed before. Ill try to post a pic later today, but as of now I am stumped as to how to remove them.
Old Jun 29, 2007 | 09:45 AM
pws69's Avatar
pws69
Originally Posted by FLYNRYN
Hmmm....
You must drill and punch out the rivets first - rotors will then pull off.
Old Jun 29, 2007 | 10:48 AM
Stewart's74's Avatar
Stewart's74
Even if the rivets are gone, the rotor still may be difficult to remove from the spindle if it is a tight fit and there is some corrosion...
Old Jun 29, 2007 | 12:27 PM
Mike Ward's Avatar
Mike Ward
Why not just remove the rotor and the hub in one piece- just like GM intended.
Old Jul 2, 2007 | 01:41 PM
FLYNRYN's Avatar
FLYNRYN
Default oops
Newbie mistake. It just LOOKED like the rivets were in place, but things got much easier after I removed the spindle nut:o Glad I did, tho, as the front wheel bearing on the driver side had a chunk the size of 3 BBs removed from a roller. This after I just paid a mechanic to tell me that the front bearings are fine This is why I do more and more by myself as time goes by......
Old Jul 2, 2007 | 03:44 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Sometimes you have to change rotors...GM only did that so that the line workers could throw throw things together quickly - the rotor faces were already squared to the hubs.
Old Jul 2, 2007 | 11:05 PM
Mike Ward's Avatar
Mike Ward
Umm, no. The original intent was to change both the hub and rotor in the field, not just the rotor.
Old Jul 2, 2007 | 11:44 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I need to check my GM service manual - I'm pretty sure it says something about drilling out the rivets to remove the front rotors, but I might be wrong. Anyway, does anyone sell the rotors and hubs as a unit anymore? It seems needlessly expensive and wasteful if your hubs are in good shape.
To 69 Brake Rotor Removal
