brake fluid loss?
Old Jun 29, 2007 | 11:20 AM
dogboy's Avatar
dogboy
Default brake fluid loss?
I lost my fluid in the rear master cylinder chamber. I refilled it , bled system & all seems well. For the life of me I can't find a leak anywhere in the system, any ideas where it could have gone.It is a 77 daily driver
Old Jun 29, 2007 | 12:13 PM
Dick Whittington's Avatar
Dick Whittington
Look on the bottom side of the brake booster. Sometimes the master cylinder will leak and it will run down the front of the booster
Old Jun 29, 2007 | 12:39 PM
piper.gras's Avatar
piper.gras
check the inside sidewalls of your tires. if there's fluid staining on any of them, they you've got a leak in one or more of your calipers. they're easy to rebuild with new boots/seals if that is your problem.
Old Jun 29, 2007 | 04:57 PM
GTR1999's Avatar
GTR1999
Get a Motive bleeder, pump it up on each section of the M/C to 10 psi and see if the gauge drops. If it drops on both check the M/C seal if only in one section look from the lines to the calipers for a leak. It's not evaporating so it has to show somewhere.
Old Jun 30, 2007 | 04:21 PM
dogboy's Avatar
dogboy
Good advice. I'm thinking a slow leak somewhere. I did the master cylinder about 3 yrs ago due to failure . I also did the calipers from VBP all around with new hoses & brake lines to rear from hose to junction over the rear diff. about 4- 5 yrs ago.. Where to get a Motive bleeder??
Old Jun 30, 2007 | 04:23 PM
dogboy's Avatar
dogboy
Never mind I found the Motive website.
To brake fluid loss?
