True Dual exhaust ?
Thanks!
Shorty or block hugger headers are available from many sources...speed shops, Summit Racing, and Jegs. I like Sanderson, but there are lots of good brands...get coated, not plain painted.
No matter what you do you will have to have the muffler shop weld the collectors to the pipe.
My exhaust, headers, pipes and Flowmasters cost $450.
Something to keep in mind - any deviation from the factory exhaust design before the catalytic converter is in violation of federal emissions regulations. That said, many states have rolling exemptions where vehicles over a certain age don't go through emissions testing, and therefore are exempt as a practical matter. You don't want to spend a bunch of money on an exhaust, only to find out that you can't license your car.
You will need to keep your left pipe on the left side because the angle bend from the collector to the right side will be too sharp as this picture shows:
You'll need to make a simple mod to the cross member to get enough clearance under the left pipe. (I have 1/4" more under the left than the right pipe in the stock position with this mod.) I used a 1x4 with a 3 1/2" half circle cut off the end as a template. I cut the 1x4 to length from the floor (or lift ramp in my case) to just below the cross member seam. I positioned the 1x4 about half way between the transmission and driver's floor pan. I used spray primer to create a shadow of the 1x4 on one side, masked the cross member bottom, and made the same shadow on the other side of the cross member.
Then I used an air cutoff tool to cut out the cross member.
(I took advantage of the opening and treated the surface rust inside the cross member.)
The guy at my favorite performance muffler shop split a piece of 3 1/2" pipe lengthways and welded it into the cross member. I ground things smooth, primed, and painted the modified cross member.
Then I took it back to the shop for pipes and H-pipe. He used as much of my old system he could to save some $$, so there are a few unnecessary bends. This system sounds great and the performance gain was obvious on my butt-o-meter!
Give it a listen!
http://s124.photobucket.com/albums/p...t=MVI_0207.flv
BTW, I have Dynomax full length ceramic headers from Summit and Flo-Pro mufflers:
http://www.flopro.com/FloPro.htm
With my 80's aftermarket 700R4's cross-member, I found that buying the mailorder systems for the orig TH350 crossmember would not work; the crossmember clearance is different. And ordering the older, through the cross-member pipes was money wasted as they would not clear my 700R4's crossmember either.
Very satisfied with my choice.
P.S. The shop wrote 'cat-back system' on the receipt for my 80's dual system... Oh, and I drove the vette to the shop with open headers and short straight-pipes. A little old lady pulled up to me and told me my car needed mufflers... I told her they were in the front seat and I was on my way to have the system installed. She just smiled!
