Solid motor mounts and new mufflers
Old Jul 3, 2007 | 10:55 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Homina...
Old Jul 3, 2007 | 11:39 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Originally Posted by I'm Batman
...My 77 now has a crazy driveline setup - solid differential crossmember mounts, poly differential front mount, solid motor mounts, poly transmission mount. It should be nice and firm...
That's exactly what I've got, although I believe I'll eventually do the solid front diff. mount. I've forgotten, have you done the spreader bar yet??
Now, (repeating what I've posted in other threads on this topic...) according to TCI solid transmission mounts are the chief cause of transmission case breakage, and I've actually heard stories of it happening. Here's an "I told you so" () which can be applied when needed, in case anyone does it anyway and it goes wrong.
Old Jul 4, 2007 | 12:02 AM
King Lear's Avatar
King Lear
Veteran
Sweet, now were doing some tech talk
Old Jul 4, 2007 | 12:04 AM
King Lear's Avatar
King Lear
Veteran
Originally Posted by Edzred72
Wayne: Forget about it...I saw her first.
Eddie
Sweet, now were doing some tech talk!
Old Jul 4, 2007 | 12:11 AM
SEVNT6's Avatar
SEVNT6
Did anyone notice Jaws in the background?
That's what I told my wife I was looking at.........
Old Jul 4, 2007 | 12:39 AM
TheSkunkWorks
I did a double take at that too, but not before asking myself, "Is that Hawaiian Tropic or Banana Boat?"
Old Jul 5, 2007 | 10:36 AM
The Money Pit's Avatar
The Money Pit
What's the part number for these solid mounts. I started poking around,and apparently there are different heights,depending on the chassis they go into.
Didn't mean to derail the beach party we're having here.
Old Jul 5, 2007 | 10:46 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
62530. Summit's website can be sorted by application - I checked there, and that's the part number I ordered from them. They fit fine.
Old Jul 5, 2007 | 11:09 AM
The Money Pit
Thank's. I also confirmed this on Moroso's site.
Now back to the beach!
Old Jul 5, 2007 | 03:39 PM
Frank_833's Avatar
Frank_833
Originally Posted by Blue Juice
...I think if you did the same swap on a monocoque chassis, then vibration would be an issue...
Had solids on a V8 Vega with NO cage or bracing. Vibration was not a problem. Twisted the car plenty, but no vibration issues.
That has to be close to the worst case for a daily driver.
