security
Old Jul 3, 2007 | 02:48 PM
Capt Ron1156's Avatar
Capt Ron1156
1st Gear
Default security
I have a 1970 vette convertable, big block. Recently I spent alot of money for a candy apple red paint job. I will be getting lojack with the early warning. I also have a steering wheel to clutch lock but I still want more security. Any suggestions?
Ron
Old Jul 3, 2007 | 03:06 PM
desi's Avatar
desi
Alarm system
Park in garage
Battery disconnect
Fuel cut-off
Rottweilers
Old Jul 3, 2007 | 06:25 PM
saudivette's Avatar
saudivette
I have a cover thing that goes around the steering column and covers the ignition barrel. I'd imagine that a pro could get it off but it would make it hard for anyone else to break the steering lock.
Mind you, over here there isn't a great deal of car theft - they cut your right hand off if you're caught...
Old Jul 3, 2007 | 08:30 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I have a feeling that in the US, we'd just have a bunch of handless people...
Old Jul 3, 2007 | 08:40 PM
chris75stingray's Avatar
chris75stingray
you could get one of those boots to lock around the rim. i saw one on a camaro once for a security device. there pretty expensive though
Old Jul 3, 2007 | 10:38 PM
spedaleden's Avatar
spedaleden
Put square wheels on it.
Just remember if someone really want it they will just flat bed it. Nothing you do will stop the professional.
Old Jul 3, 2007 | 10:42 PM
SmokinBBC's Avatar
SmokinBBC
Put a sticker on the window "Protected by Smith & Wesson"
Old Jul 4, 2007 | 01:15 AM
Z-man's Avatar
Z-man
Nothing beats a garage without windows - nothing!
When you drive and park, it never leaves your sight...
Old Jul 4, 2007 | 01:28 AM
Secret Squirrel's Avatar
Secret Squirrel
"Nothing in this car is worth your LIFE"
Old Jul 4, 2007 | 01:29 AM
Carl Granquist's Avatar
Carl Granquist
N/A profiles really don't let us help you as much as we might.
"Always keep it in sight" is a good rule-of-thumb. A lot of us enjoy weekend cruising, informal shows, short destination visits, etc. Not so much leaving it in a shopping mall parking lot for an evening.
Just a thought.
Old Jul 4, 2007 | 02:41 AM
RPOL68's Avatar
RPOL68
I have always liked the fuel cut-off idea. On a carbureted car it allows a thief to get out on the road then stalls the car. He is not as likely to stick around to figure out why when he's in the middle of a public roadway.
Old Jul 4, 2007 | 04:20 AM
saudivette's Avatar
saudivette
I always thought a wheel clamp would be a pretty good way to secure your car...
Old Jul 4, 2007 | 07:11 AM
Paul L's Avatar
Paul L
Boot.
Old Jul 4, 2007 | 08:05 AM
AWilson's Avatar
AWilson
Heres the website:
http://www.alphalock.com/
looks Like you can get it for < $150
Old Jul 4, 2007 | 08:16 AM
SmokinBBC's Avatar
SmokinBBC
Even Better!
I have a hidden ignition cutoff switch and a battery cutoff. Don't know if that is good enough to stop a theif...but it will certainly slow 'em down a bit.
Old Jul 4, 2007 | 09:47 AM
Paul L's Avatar
Paul L
I got mine for $90.00 on EBay. Here's one for $110.00 although it may be the truck model.
http://cgi.ebay.com/ebaymotors/TIRE-...QQcmdZViewItem
Old Jul 4, 2007 | 09:59 AM
rosslato's Avatar
rosslato
i've got the pedal lock and 2 fuel cutoffs a kill switch switch and the vette is alarmed and so is the garage. i hate for things to be stolen from me.
Old Jul 4, 2007 | 12:25 PM
SmokinBBC's Avatar
SmokinBBC
Only left is to remove one of the wheels like they do on bicycles
Old Jul 4, 2007 | 12:53 PM
Serge144's Avatar
Serge144
I wired my 77 factory alarm to a starter kill.
I used a 3m t-tap to splice into the yellow wire from the factory alarm relay. When the alarm is tripped this wire switches to a ground -- you may have to probe if the wire color is different. I wired the relay near the factory alarm relay which is right below the shifter assembly. The only wires you have to cut are from the neutral safety switch which can be replaced if you wanted to return to stock.
I cut the purple wire from the neutral safety switch and connected each end to terminals 87 and 87a. I tapped into a constant 12v (lighter) and connected that to terminal 86. I connected the tapped line from the yellow wire from the factory alarm to terminal 85. Terminal 30 is left open.
The relay is only switched when the alarm is tripped and if it fails the car will start and not leave you stranded.
To security
