offset A-arm shafts
Old Jul 4, 2007 | 06:48 AM
Joe45's Avatar
Joe45
Default offset A-arm shafts
Using a used replacement frame for my 81. Ready to assemble it. A-arms etc. Not knowing shim content previously, would it make sense just to go for the offset arms up front just in case?
Old Jul 4, 2007 | 07:28 AM
SARASOTA SAM's Avatar
SARASOTA SAM
Not sure but read my request lower down about 72 a-arms it may be of interest.
Im sure you will measure up your replacement frame just incase but do closely inspect bottom a-arms rear pivot point"wings" and shaft if not brand new.Also bracket/gusset welded to frame cross member.
Old Jul 4, 2007 | 08:08 AM
Joe45's Avatar
Joe45
I have a frame chart and mount to mount(body) is good. Never wrecked. All welds good on A-arm mounts. Chart does not show a dimension from shock tower to shock tower. If I had that maybe that would tell me if the frame has seen some sagging which I understand is normal over time. I think this is why offset arms and spreader bars are used. Any body have dimensions for tower to tower?
Old Jul 4, 2007 | 10:43 AM
norvalwilhelm's Avatar
norvalwilhelm
Regardless of which arms you use I like to mill a slot, elongate the holes in the cross shafts 1/4 inch to the front. This allows alot more caster to be added without using shims.
To offset A-arm shafts
