Hooker super comp install question??
Old Jul 6, 2007 | 01:07 AM
blunblk68's Avatar
blunblk68
Default Hooker super comp install question??
when you guys installed your side exhaust hooker headers did you have to lift the engine on either side?? Or did they slip in with no motor movement??? thanx
Old Jul 6, 2007 | 04:40 AM
GDaina's Avatar
GDaina
no
Best to bolt the exhaust gasket to the flange and ream bolt holes first, then mount the headers
Old Jul 6, 2007 | 08:38 AM
Edzred72's Avatar
Edzred72
Originally Posted by GDaina
no
Just did this last weekend. The drivers side is tricky, so you need to get the car up pretty high. With the headers pointing up and collector down, slip the #1 cyldr pipe by the steering box as close to the frame and as low as you can...than tilt it up. Hard to explain, but the only way it clears. It helps if the starter is out on the other side.
Good luck...
Eddie
Old Jul 6, 2007 | 10:04 PM
ddale1977's Avatar
ddale1977
Just installed my Hooker sidepipes this weekend. I had the motor out and tied them up out of the way inside the motor compartment before installing. Make install much easier. Looks very tight otherwise.
Old Jul 7, 2007 | 05:31 PM
Tankers's Avatar
Tankers
Take the body off
Old Jul 7, 2007 | 07:04 PM
GDaina's Avatar
GDaina
just raise the car high, and you will have to dent one of the tubes to clear the steering box.
Old Jul 9, 2007 | 11:36 AM
Edzred72's Avatar
Edzred72
Realy George? Luckily I didn't have to. Maybe because it was up so high??????????????????
Eddie
Old Jul 9, 2007 | 12:09 PM
Glassbowtie77's Avatar
Glassbowtie77
I put my car up on ramps. The passenger side went right in without a hitch. For the drivers side I had to jack it up a bit higher than what the ramp was giving me. I laid a blanket on the ground and covered the steering box with a towel so I wouldn't scratch up the header and then carefully maneuver it around to get it past the steering box. It is a little more tricky to get bolted up than the passengers side so be patient and have someone (my wife helped me ) under the car to help you guide and then hold in place until you get the bolts started into the head. You need to remove the spark plugs, temperature sending unit and oil sender on the drivers side in order to get it in there, I didn't have to remove my starter, but I did make sure that the wires going to it had sufficient clearance from getting burned. All total with cutting out my old system I'd say it took me about 4 hours to do.
Old Jul 9, 2007 | 07:29 PM
GDaina's Avatar
GDaina
Eddie
Me baaaaaaaad........daaaaaaaaah......small block....
Big block a tube has to be dented.....oh well...that's what I get for thinking past experiences....
To Hooker super comp install question??
