Electric fan only?
Old Oct 29, 2001 | 10:23 PM
carlmb's Avatar
carlmb
Default Electric fan only?
Is anyone out there running just electric fans? I have a 71 and I'm getting ready to pull the engine for a rebuild and I would like to eliminate the mechanical fan to help clean up the engine compartment. Any recommendations would be appreciated. Thanks in advance.
Old Oct 29, 2001 | 10:26 PM
QuickVet's Avatar
QuickVet
Default Re: Electric fan only? (carlmb)
check out the flex-a-lite web site: http://www.flex-a-lite.com/
Old Oct 29, 2001 | 10:34 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: Electric fan only? (Vetteboy)
Dual 12" flex-A Lites cool my 460hp 434cubic inch small block with a stock brass ( but re-cored ) radiator.
Old Oct 29, 2001 | 10:38 PM
467-Ratman's Avatar
467-Ratman
I put a BeCool radiator on my 71 coupe this summer with twin Spal fans, they work great. The fans turn on at 195 and off at 180, in less than one minute they turn off! Very powerfull, highly recommend them. The engine compartment looks great with the fan shroud gone, you will really like it. I am also in the process of rebuilding my motor, just pulled it out two weeks ago. Good winter project!
Old Oct 29, 2001 | 10:40 PM
QuickVet's Avatar
QuickVet
Default Re: Electric fan only? (427V8)
how do you make a 434 ci small block engine?
[Modified by Vetteboy, 9:40 PM 10/29/2001]
Old Oct 29, 2001 | 10:47 PM
Monty's Avatar
Monty
4.00" stroke and a 4.155" bore (.030" over 4.125" SBC 400 bore).
Old Oct 29, 2001 | 10:50 PM
carlmb's Avatar
carlmb
I measured the core area on my radiator and it is approx. 17X17. The dual fan set ups are much larger than this.(approx. 16x26) Do yours overlap the core on each side? Thanks.
QuickVet's Avatar
QuickVet
Default Re: Electric fan only? (Monty)
i have never heard of that. wow, must make alot of torque. :eek:
Old Oct 29, 2001 | 10:51 PM
QuickVet's Avatar
QuickVet
what about the black magic fan? that is what i was planning on buying some day. would that work for you?
Old Oct 29, 2001 | 11:27 PM
daily_driver's Avatar
daily_driver
im running the dual flex a lites on a recored 4 core radiator!!
here in florida it cools wonderfully!!
never have any problems with it.
Old Oct 29, 2001 | 11:39 PM
Rumpity Rump's Avatar
Rumpity Rump
Default Re: Electric fan only? (daily_driver)
I have a 1970 BB, and im using a dual electric fan assembly out of a 90's LT 1 Vette. Fits perfectly and moves mega air. Cools 540 h.p well.
R.R.
Old Oct 30, 2001 | 01:17 AM
phat82's Avatar
phat82
I've got an 82 all stock. I bought a 3 core brass/copper rad from radiatior.com and a set of dual 11" Spals behind it. Haven't had a bit of trouble. In fact I had the upper hose go out on me and lost about half my coolant and she never budged over 185. Plus I would recommend a bottle of motor max. And I guarontee you'll see an improvement at the rear wheels.
[Modified by phat82, 11:17 PM 10/29/2001]
Old Oct 30, 2001 | 06:26 AM
Ingar, Norway's Avatar
Ingar, Norway
I only have an electric fan. Bubba project, you can read more in the technical section of my page.
In our climate, with summer temperature around 20degC ( 68oF) the fan is only needed during traffic jams and long stops.
The fan has been running max 5 times this season.
Old Oct 30, 2001 | 06:45 AM
DREGSZ's Avatar
DREGSZ
Default Re: Electric fan only? (phat82)
just put in Be Cool/spal dual electric fans on a stock radiator, nice fit, no overlap, not 160 thermostat, stays cool
Old Oct 30, 2001 | 08:05 AM
427V8's Avatar
427V8
My Radiator is 26" wide and about 18" tall. The dual Flex-A-Lites fit perfectly.
I don't believe there is a real need for the fancy aluminum radiators. They just lighten your wallet....( OK if you really feel the need to lighten the front end of your car, I suppose it would help.
If the stock rad can cool my big small block I think it can cool most anything!
And yes it's been tested! At the Car Craft summer Cruse last year it was in the high 90's and I spent a LOT of time driving around the fairgrounds without it getting hot at all. I've also been autocrossing with it and it kept it's cool just fine.
VetteBoy;
460 Hp, 500 ft/lbs, enough torque?
[Modified by 427V8, 6:07 AM 10/30/2001]
Old Oct 30, 2001 | 08:15 AM
Maco Shark's Avatar
Maco Shark
I'm running only electric fans on my Purple shark. I have it on a switch instead of being controlled by thermostat. This way, I can cut it on early in anticipation of heating problems, like getting in heavy traffic.
Hope this helps.
Old Oct 30, 2001 | 08:28 AM
SteveG75's Avatar
SteveG75
BeCool with dual Spal fans here. Consensus is that Spal fans flow better than the cheaper ones. Here is a pic to wet your appetite:
Old Oct 30, 2001 | 11:11 AM
Mike69@ECS's Avatar
0Mike69@ECS
Former Vendor
Cruise-In III Veteran
Cruise-In V Veteran
Sounds like you have the same set up I had. Your car must be a small block without air. I just Changed my radiator, fans & Core Support to the 26 in support .... Check out this thread - it's got all the info you'll need!
http://forums.corvetteforum.com/zerothread?id=173121
Old Oct 30, 2001 | 11:33 AM
81vette's Avatar
81vette
Anybody know the weight difference between an aluminum and brass radiator?
[Modified by 81vette, 12:27 PM 10/30/2001]
To Electric fan only?
