81 won't start- help needed!!
Old Jul 6, 2007 | 04:31 PM
JLinCA's Avatar
JLinCA
Default 81 won't start- help needed!!
I just got done with hooking up everything after an intake gasket change and now the 81 won't start. The engine turns over normally but it just won't fire up. There is also a heavy gas smell coming from the carb. Nothing was touched on the carb, it was taken off and put back on with tampering.
Everything has been hooked up as it was before the gasket change, and the car ran great before. The only thing I changed in the whole install was the addition of a exhaust restrictor plate on one intake gasket. Could this affect starting?
The car has the original E4ME carb.
Old Jul 6, 2007 | 05:24 PM
spedaleden's Avatar
spedaleden
It sound like a no spark situation. Is the dist pluged back in?
Old Jul 6, 2007 | 06:00 PM
JLinCA's Avatar
JLinCA
Yes everything is hooked up as before.
Old Jul 6, 2007 | 06:02 PM
SIXFOOTER's Avatar
SIXFOOTER
Yep, sounds like a straight up ignition problem. Make sure you got everything reconnected correctly on the dist and also that you got the dist indexed correctly. Your getting the gas smell because your pumping the gas pedal but its not fireing, so your flooding it.
Old Jul 6, 2007 | 06:25 PM
billsfan's Avatar
billsfan
I had the same problem.Turns out the distributor was off about 1". I bumped the engine to get the balancer mark lined up on the timing tab, then pulled the distributor and installed it pointing at the #1 plug wire. That should get it to start, then use a timing light to zero it in. Good Luck!
Old Jul 6, 2007 | 06:31 PM
DeeVeeEight's Avatar
DeeVeeEight
It sounds like you removed the distributor, then re-installed it incorrectly. To correct this you must get the number one cylinder to top dead center, then re-install the distributor so that the rotor points at the number one cylinder (plug wire). That should get you in the ball park, you may have to rotate the distributor a bit by hand while cranking the engine to get it to fire, then use a timing light to set it right.
Good luck!
Old Jul 6, 2007 | 06:36 PM
JLinCA's Avatar
JLinCA
Good luck!
I think that's exactly what I did, not installing the distributor correctly. This was my first time ever doing this. I was just reading Lars's paper on TDC and I am going to do this next.
Old Jul 6, 2007 | 06:37 PM
JLinCA's Avatar
JLinCA
Thanks for getting me on the right track guys!!!
To 81 won't start- help needed!!
