quad to manifold what gasket??
Old Jul 7, 2007 | 10:22 AM
sxr6's Avatar
sxr6
Default quad to manifold what gasket??
Is there any place to check which carb base gasket to use between the manifold & Quad carb?? I understand there's 3 possible gaskets.
My BB just won't run right, uses a ton of fuel & I'm begining to suspect I have the wrong base gasket. What would the syptoms be if it was wrong?
The intake is a 1976? cast iron & the carb & gasket I'm using temporarily is from an 86 truck.
