headlight problem on start up !
Old Jul 7, 2007 | 11:01 AM
vettephyxer's Avatar
vettephyxer
Default headlight problem on start up !
Started my 78 today and the left headlite came up slowly, then the right, ( light switch in off position, lights did not come on). They stayed up for a couple of minutes then went down slowly. I looked for vacume leaks but found none. Help !!.
Old Jul 7, 2007 | 11:05 AM
Duke94's Avatar
Duke94
Check for a leaking check valve from engine to vacuum tank.
Old Jul 7, 2007 | 11:20 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Replace the check valve and the filter located on the driver side of the engine by the vacuum source. (right in the middle of the intake manifold) A clogged filter, or a bad check valve will cause this problem.
Willcox Inc.
Old Jul 8, 2007 | 04:43 PM
vettephyxer
Default got it !
Yup-old cracked check valve, thanks!
To headlight problem on start up !
