427" Small Block....Oil pan ?
Old Jul 7, 2007 | 03:41 PM
C3 Stroker's Avatar
C3 Stroker
Default 427" Small Block....Oil pan ?
After the mishap with the 383, I have decided not to rebuild but to have another engine built. It will be a 427" small block, 4.00" stroke.
My question.....what oil pan are you guys using? I want around 5-6 qt. capacity and no "fitment" issues. This will be for a '69 automatic, so the right side can't kickout to interfere with the trans. cooler lines. Also, don't want it to hang more than 1/2" lower than stock for ground clearance. Suggestions and part numbers helpful.....thanks.
Old Jul 8, 2007 | 12:36 PM
C3 Stroker's Avatar
C3 Stroker
ttt
Old Jul 8, 2007 | 03:19 PM
jbowles49's Avatar
jbowles49
Default oil pan
I would check with Milodon and Moroso. I have had excellent service with Milodon but I'm sure the same could be said for Moroso.
Old Jul 8, 2007 | 05:07 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
www.billetfab.com
Old Jul 8, 2007 | 05:48 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Hamburger # 1088. Make sure you get the pan rail spreaders part # 1188 also. They eliminate every other bolt to get clearance and the spreaders eliminate leaks caused from this.
Old Jul 8, 2007 | 09:10 PM
C3 Stroker's Avatar
C3 Stroker
Thanks. I like that one better than the Moroso or Milodon comparables.
The Canton #13-082 looks good also.
Old Jul 9, 2007 | 02:26 AM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
i went with the hamburger #3047 with the kick outs on my 396. it will work with a 4" stroke. i used a 1 piece gasket and the spreader kit. here are a few pics.
To 427" Small Block....Oil pan ?
