Rear suspension issues.
Old Jul 7, 2007 | 10:20 PM
69coupe's Avatar
69coupe
Default Rear suspension issues.
Hey all,
I have a rear suspension problem. Pulled the vette into the garage yesterday and heard a pop from the rear end. I parked the car and the left rear tire was at a funny angle. I just jacked the car up and now I can "wiggle" the tire in all directions abit.
Any thoughts or ideas would be appreciated.
Old Jul 7, 2007 | 10:58 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
a bit is too much.
probably been a while since it's been touched so i would suspect bearings, maybe spindles if you can wiggle it much.
Old Jul 7, 2007 | 11:03 PM
shafrs3's Avatar
shafrs3
Rear wheel bearings.
Old Jul 7, 2007 | 11:18 PM
69coupe's Avatar
69coupe
Ok wheel bearings are cheep enough. What kind of trouble is it to replace them?
Old Jul 7, 2007 | 11:23 PM
LB66383's Avatar
LB66383
No problem at all, if you have the right equipment. Like a press and the special tools. Rear wheel bearings are not your average garage job. My advice is to remove the trailing arms from the car, pull the spindle assemblies, and send them to VBP or Van Steel to be rebuilt. I believe they warranty their work for several years.
Old Jul 7, 2007 | 11:33 PM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
You need to give the rear end a good look from underneath to see what's wrong. If something is moving, you need to figure out what it was. Could be a wheel bearing, but it could also be a u-joint, or something could have come loose with the camber rods or the toe-shims.
Have someone wiggle the tire and look underneath to see what's moving.
Wheel bearings in thr rear are nothing like normal front bearings. They need to be pressed in & out and shimmed properly. There are specialty tools available for doing that job if you're so inclined. While the arms are out of the car for that, you might as well go though the rest of the arms and put in new bushings and make sure the e-brake is in good working order. It's one of those "I could do it with the proper tools, or I could pay a little more to have it done and have some piece of mind" jobs.
Old Jul 8, 2007 | 12:12 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
T/As are a rather specialized job.
Old Jul 8, 2007 | 11:03 AM
Avette4me's Avatar
Avette4me
Wheel bearings in thr rear are nothing like normal front bearings. They need to be pressed in & out and shimmed properly. There are specialty tools available for doing that job if you're so inclined. .
i now own some of those "special" tools. An arbor press to press the assy apart, ruined spindle (waited too long) for setting the bearing endplay (ground down so the bearings are removable after end play is set), and the tail shaft off of a turbo 350 for pressing them back together.
getting the end play right is really the most technical part imo, .02 to .08 isn't a lot.
Old Jul 8, 2007 | 11:09 AM
69coupe's Avatar
69coupe
Sounds like I will leave this one to the professionals, any thougts on who does the best job and the most economical?
Old Jul 8, 2007 | 11:18 AM
Avette4me's Avatar
Avette4me
Corvette central does it...
click here
Old Jul 8, 2007 | 11:21 AM
shafrs3's Avatar
shafrs3
Any of the forum sponsers like Van Steel do a great job, never seen any complaints here.
Old Jul 8, 2007 | 06:58 PM
GTR1999's Avatar
GTR1999
Be sure you know where the problem is. Check the rear spring bolts they break the cover at time. If the bearing are bad you'll know it - jack up the rear of the car and see how they feel.
The correct way to setup rear bearings is to grind the shims to size rather then use the generic shim kits. Big difference in the job.
Old Jul 8, 2007 | 10:51 PM
Avette4me's Avatar
Avette4me
that's good news to me. just completed my first one and had to grind (bench sander) a shim on one side to get into spec (.04 on that one).
Old Jul 9, 2007 | 10:36 AM
69coupe's Avatar
69coupe
Thanks as always for all the information.
To Rear suspension issues.
