how to do a turn signal switch replacement?
Old Oct 30, 2001 | 06:54 AM
DREGSZ's Avatar
DREGSZ
Default how to do a turn signal switch replacement?
I can't find the switch in the owner's manual,
what all is involved in replacing the switch?
Can I put a W/O switch in a Tele car?
They don't make the tilt/tele switch anywhere, anymore.
Is it a major undertaking?
Old Oct 30, 2001 | 07:43 AM
V8yunkie's Avatar
V8yunkie
Default Re: how to do a turn signal switch replacement? (Evan Ginsberg)
Try the http://www.corvettesteering.com page:They have about everything around the steering columns.
Good luck
Old Oct 30, 2001 | 07:45 AM
V8yunkie's Avatar
V8yunkie
OH, and BTW there is a nice link in the http://www.corvettefaq.com to a document how to disassemble the steering column. Have a look!
Thomas
Old Oct 30, 2001 | 09:04 AM
Jim Shea's Avatar
Jim Shea
You cannot use a standard (non-adjustable) turn signal switch in a T&T column. The 1969 thru 1976 T&T turn signal switch is becoming very hard to find. One good thing is that any General Motors T&T steering column from the 1969 - 1976 time frame should be able to supply a switch that should bolt right in. The wires running down the column from the switch might be a bit too long, but the switch (if it is in good condition) should work. Several papers that are posted at http://www.corvettefaq.com should be of value to you. Go to Suspension and Steering and look up:
Tilt & Telescoping Blowup Pic
Tilt & Telescoping Disassembly Instructions
Tilt & Telescoping Disassembly Pics 1, 2, & 3
Where to get replacement steering parts
Old Oct 31, 2001 | 03:31 AM
DREGSZ's Avatar
DREGSZ
Default Re: how to do a turn signal switch replacement? (V8yunkie)
Thanks,
I'll call corvette sterring in the AM
Evan
Old Oct 31, 2001 | 08:22 AM
Jim Shea's Avatar
Jim Shea
You might also try: http://www.columnsgalore.com
To how to do a turn signal switch replacement?
