Ideal Kick Panel Speaker Size
Old Jul 9, 2007 | 12:03 AM
80TexasC3's Avatar
80TexasC3
"Rodstoration &am p;quot; In Progres
Default Ideal Kick Panel Speaker Size
What speaker sizes is everyone running so that the front kick panel speakers can fit flush against the kickpanels and the maginet fit within the body mount access?
Thanks in advance for any and all input.
ed
Old Jul 9, 2007 | 11:43 AM
ajrothm's Avatar
ajrothm
5.25"s fit with only minor "clearancing" to the bird cage. They will fit behind the kick panel totally. I believe the 6.5"s will also fit but must be mounted on the outside of the kick panel or custom kick panels made.
I used the 5.25s because I didn't want to cut up my kick panels or have big speakers visual.
Old Jul 9, 2007 | 02:31 PM
80TexasC3's Avatar
80TexasC3
Thanks!
Old Jul 9, 2007 | 04:00 PM
monza_man's Avatar
monza_man
I just threw in some 4x6's, basically a direct replacement with no clearance issues at all. They have less low-end response than the 5.25's though.
Old Jul 11, 2007 | 09:04 AM
Ganey's Avatar
Ganey
Some 5.25 can be mounted in the kicks properly (solidly mounted w/ a plate) w/o mods to the kick panel. 5.25 is ideal for natural sound. There is not enough airspace behind to optimize 6.5s which should go into doors. The off axis response of the 5 1/4 should be better than a larger 6 1/2.
With separate tweeters or adjustable- angle up & back.
monza_man & others w/ 4X6
I just recently got around to front speakers & did some experiments using 4x6 since they fit easily. (Disconnected the dash speakers in the 70s.)
Typically a plate is needed for mounting since the back waves need to be separated from the front.
I figured the lack of airspace was an issue & tested them in doors & they sounded much better.
Kenwood eXcelon 5.25 Components in kick panels.
Old Jul 11, 2007 | 11:12 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
4x10s (stock for 68 and 69) will fit behind the kick panels.
Old Jul 11, 2007 | 05:28 PM
Ganey's Avatar
Ganey
The bird cage was reinforced on later models & the speaker opening is about 5 3/4" H X 4" W.
Old Jul 11, 2007 | 07:38 PM
guitarcrazy02's Avatar
guitarcrazy02
You drive a C3. You're supposed to have a lousy stereo, that's what the exhaust is for!
Old Jul 11, 2007 | 08:44 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
4x10 speakers are far, far from "ideal."
Old Jul 11, 2007 | 09:09 PM
monza_man's Avatar
monza_man
Old Jul 11, 2007 | 10:51 PM
ikesterx's Avatar
ikesterx
I have 5.25s they fit nicely, others have 6.5s as well.
Old Jul 11, 2007 | 11:12 PM
Busrydr's Avatar
Busrydr
Will these mount behind the kick panels without a plate or modification?
Old Jul 12, 2007 | 08:26 AM
Ganey's Avatar
Ganey
Busrydr
A mounting plate should be used to separate the front from back sound waves to prevent cancellation so a plate was used. 5.25 Components behind factory kick panels though some additional holes were opened in the panels.
Old Jul 12, 2007 | 01:42 PM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
I have 6.5", but they are mounted at an angle. I only used the opening for part of the magnet, not the whole thing.
Old Jul 12, 2007 | 04:06 PM
Overlord's Avatar
Overlord
From: Crush your enemies, see them driven before you, and hear the lamentations of the women TX
I like those. How did you rig them up?
To Ideal Kick Panel Speaker Size
