Radiator Insulation
Old Jul 9, 2007 | 04:26 PM
ENCHANTMENT's Avatar
ENCHANTMENT
Default Radiator Insulation
Hi All,
Any one know a source for adhesive backed insulation to go between the shroud and radiator. I am looking for a fairly dense insulation/sealing medium that will tolerate heat. This is not for a stock radiator or shroud.
Many thanks,
Ken
Albuquerque, NM
Old Jul 9, 2007 | 04:52 PM
Durango_Boy's Avatar
Durango_Boy
At Wal-Mart and most hardware stores they sell window A/C unit insulation that's usually adhesive backed and comes in several lengths, thicknesses, and some come in rolls.
Old Jul 9, 2007 | 04:56 PM
Xakk's Avatar
Xakk
I used dense pipe insulation bought from Lowes and 3M weatherstrip adhesive (the yellow stuff)
Old Jul 9, 2007 | 05:59 PM
ENCHANTMENT
Hi,
I bought some of the A/C foam insulation but after opening it up, it didn't look like it would hold up. The dense pipe insulation sounds more like what I am looking for.
Any other ideas?
Ken
Old Jul 9, 2007 | 07:03 PM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
Another way to attach the pipe insulation is with double-sided tape. I used golf grip tape for a couple of weeks years ago while I was waiting for my Doc Rebuild set of radiator seal to arrive. If you want to do it right and look good, consider Doc Rebuild's kits.
Old Jul 9, 2007 | 07:59 PM
ENCHANTMENT
I would normally use a kit but since this is not an original radiator or shroud, I doubt that the cut to fit would work.
Thanks again,
Ken
Old Jul 9, 2007 | 08:10 PM
Sayfoo's Avatar
Sayfoo
I used the black rubber pipe insolation and black 3M weatherstrip adhesive.
To Radiator Insulation
