trannmission prob.
Old Jul 10, 2007 | 02:32 PM
charles.stencil's Avatar
charles.stencil
Default trannmission prob.
i have a 1981 corvette and i put a new 1980 carb.and a new 1980 dist.on i also did away with the emissions components along with the computer now when i drive the car the transmission will drop in 1st. at about 15mph and drop in 2nd at 25 mph but it will not drop into 3rd at all is there a add an to the transmission when you change the carb. and dist. or did i disconnect something
Old Jul 10, 2007 | 04:18 PM
SIXFOOTER's Avatar
SIXFOOTER
Hmm, the only thing that ties the CCC and Tranny together is the TCC system. If you didn't do anything to connect the Lockup Converter I can see that not working, but it should still shift into 3rd. You sure its not going to 3rd? How fast were you going? What RPM?
Just thought of something else, is the Vacume Modulator still connected to the manifold?
Old Jul 10, 2007 | 05:05 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
i don't think it would shift at all then, other than manually.
Old Jul 10, 2007 | 05:33 PM
charles.stencil
i can go from 0 to 85 mph and it only drops in to 1st and 2nd at 15mph and from 25 to 35mph and nothing at 45mph and i no nothing about a vacume modulator or weather it is discinnected or not do you have a photo of what it looks like and where it goes to go to and from . i am verry new at doing my own work
Old Jul 10, 2007 | 05:39 PM
wnmech's Avatar
wnmech
I am not really familiar with the 81 corvette transmission but a lot of the gm automatics that have the computer lock-up system also have a cable that replaces the old kickdown cable that is adjustable that controls the shifting of transmissions If I remember correctly it is called something like the TCC cable. If it dont have that and has the vacumn modulator it is a round small a little bigger than a shot glass that attaches to the rear of the passengers side of the transmission with a vacumn line that runs up to a tee at the rear of your intake manifold
Old Jul 10, 2007 | 05:43 PM
charles.stencil
thank you verry mutch
Old Jul 10, 2007 | 07:17 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Sounds to me like you messed up the kick down cable. It's on the driver's side and connects to the carb. Properly adjusted, it lowers the gear when you stomp on it. If misadjusted, it'll keep it from upshifting.
Old Jul 10, 2007 | 07:42 PM
charles.stencil
can you explaine to me how to adjust the kick down cable
Old Jul 11, 2007 | 12:29 PM
CA-Legal-Vette
Pretty simple if all the parts are correct and stock. There is a button on the side of the cable where it connects to the bracket at the carb. With the engine off and the throttle fully off, press the button. This SHOULD release some cable if it is adjusted incorrectly. To adjust the cable, push the gas pedal to the floor. That's all there is to it. The cable is self adjusting.
If the cable, bracket or linkage is after market, the adjustment is a little harder.
Old Jul 11, 2007 | 03:23 PM
charles.stencil
i adjusted the cable but it is still not dropping into 3rd gear thank you for the help. also my tempiture is running hot almost to the red line on my temp. guege when i put the a/c on could that be part of the prob.i live in baltimore md i do alot of city driveing and it gets about 90/95 here remomber i am verry new at posteing on this board i am also a first time corvette owner so who ever reades my post for help please be patent i will catch on i have a feeling i will need everybody's help i am a corvette rookie. thanks . [i already no bad spelling]
Last edited by charles.stencil; Jul 11, 2007 at 03:38 PM. Reason: for got to add something
Old Jul 11, 2007 | 11:45 PM
guitarcrazy02's Avatar
guitarcrazy02
I read your post about your tranny problem today, as I usually do with all of the posts, and this one stumped me. I decided to go for a drive and didn't give the post a second thought until I was going down the road in my Vette, which is also a 1981 with disconnected computer and a 1980 carb and distributor, and watched my speedometer. If I"m correct, you claim that it drops into first at around 15 mph, second at 25, and third not at all.
If I'm correct, I don't believe you even have a problem with your transmission. From a standing stop, you are in first gear, whether you are moving or not. At normal acceleration, that 1st gear takes you through 15mph, when you transmission then shifts into 2nd gear, not first. That second gear then accelerates up to 25mph, when you then reach your final drive/3rd gear.
Just a misunderstanding, really, because what gear would you be in before 15mph? 1/2 gear?
Old Jul 12, 2007 | 09:11 AM
charles.stencil
thank you .
Old Jul 12, 2007 | 09:16 AM
SIXFOOTER's Avatar
SIXFOOTER
Damn, why didn't I catch that?
Good call Guitar
Old Jul 12, 2007 | 10:06 AM
charles.stencil
also is there something called a kickdown switch it does something when you tap on the brake my car is not doing that thanks
Old Jul 12, 2007 | 10:18 AM
SIXFOOTER's Avatar
SIXFOOTER
The switch on the brake pedal will disengage the TCC and turn off the cruise
Old Jul 12, 2007 | 10:33 AM
charles.stencil
but it is not doing that is there something disconected or a bad switch thanks again chuck ....
Old Jul 12, 2007 | 10:47 AM
SIXFOOTER's Avatar
SIXFOOTER
How do you know its not working? Once your in 3rd gear and cruising along the torq converter (TCC) will "Lockup" you can tell by watching the tach, it will drop a couple hundred rpm. keep your foot on the gas, no changes and tap the brake, the tach will jump up a couple hundred rpm.
For the cruise, same test, set the cruise and then tap the brake to disengage it
To trannmission prob.
Old Jul 12, 2007 | 11:18 AM
charles.stencil
i tried that a while back and the rpm did not drop
Old Jul 12, 2007 | 12:29 PM
CA-Legal-Vette
Good call Guitar
Sometimes we miss the obviuos while being so clever.
Nice catch Guitar.
Old Jul 12, 2007 | 12:38 PM
charles.stencil
Nice catch Guitar.
its not dropping the rpm
