Modifying a posi case bearing cap Quest?
I have the diff. out of my car & it checks out ok for now. I would like to upgrade to larger bearing caps, screw and a blue print, but that aint gonna happen right now. Sooooo I got to wondering.
Is it possible to arc weld a bead or two down the lenght of the posi case bearing cap to improve it's strength? It is bolted in place to limit distortion & a pre-heat with a torch for the cast iron per rule of thumb.
I am a hack welder, but don't have knowledge in the heat treating & metal fatique area
This would be a crutch fix until the tom's billet upgrade could be installed.
Or, since I am using a dual mount spring, I have thought about machining a flat area on the diff. cover & installing an insert & screw to make for a positive stop against the cap, similar to an after market cover on a regular diff.
If this is ridiculous, please keep it straight, without hyperbole and idiotic retorts please... thanx
For now switch to socket head cap screws in place of the hex heads.
