L82 vs. L48
Old Jul 15, 2007 | 11:36 AM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Originally Posted by Tim H
L-82s have forged crank and forged flattop pistons, big valve heads.
There is a difference.
And also a four bolt main block.
Old Jul 15, 2007 | 01:26 PM
NHRalph's Avatar
NHRalph
From what I have, the heads on the L-48 and L-83 are the same casting. 77 is 333882 and the 79's were 462624, so the real difference is forged crank, pistons and cam plus the rear Y-pipe was 2.25 for the L-48 and 2.5" fr the L-82. For engines 30 years old, I'd still go for the L-48. They both suffer from breathing and headers and real duals will help both. Most of the horsepower difference seems to be in the cam and compression ratios. I may be wrong though, regardless, get the best engine.
Old Jul 15, 2007 | 01:31 PM
sethjohnson71's Avatar
sethjohnson71
My 74 L-48 came with a 4-bolt main
Old Jul 15, 2007 | 08:27 PM
gr8whte's Avatar
gr8whte
St. Jude Donor '05-'06-'07-'08
Originally Posted by NJVette72
L48 is rated at 200 HP.
Yea back in 1972
Old Jul 23, 2007 | 12:04 AM
Hybrid117's Avatar
Hybrid117
Also l82 had a bigger cam right?
Old Jul 23, 2007 | 04:18 AM
vttedrm's Avatar
vttedrm
I waited for a 4 speed. It turned out to be an L82 to boot.
Old Jul 23, 2007 | 08:37 AM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
Yep, I was in the same boat. Thing is, if you're fulfilling your dream as a kid by getting a corvette now, you'll be wishing in 5 more years that you fulfilled your dream to get more power later. Not that the L-82 offers a whole lot more power wise, but if you do end up modifying the block, you'll be much happier with the forged crank and flat top pistons already in the block.
And these days I dont' think price is differing much between a 77 L-48 and L-82.
Old Jul 23, 2007 | 09:20 AM
USALT1's Avatar
USALT1
The L-82 shortblock is the same shortblock used in the 1971/72 LT-1. Put a replacement LT-1 cam, performer RPM intake, & headers, & you have an easy 400hp at 6500rpm. You could do this with an L-48, but the cast pistons/crank won't hold up twisting to 6500rpm.
Old Jul 23, 2007 | 08:56 PM
Hybrid117's Avatar
Hybrid117
yeah but the lt-1 cam was made for high rpms i would go with a differn't cam for a more streetable car
Old Jul 13, 2013 | 07:50 PM
jerryjoe's Avatar
jerryjoe
Default L82
L82 has a stronger cam identical to the L48 but made of stronger material.
Old Jul 13, 2013 | 09:10 PM
Barry's70LT1's Avatar
Barry's70LT1
They are different cams, see GM specs below.
3896929 L48 Used in 350 CID V-8 Good Torque Street Cam
Open Close Duration Lift
Intake 26° BTC 90° ABC 296° .390"
Exhaust 84° BBC 46° ATC 310° .410"
3896962 L46, L82 Used in Hi-Performance 350
Intake 40° BTC 100°ABC 320° .450"
Exhaust 90° BBC 50° ATC 320° .460"
Old Jul 13, 2013 | 09:11 PM
scottyp99's Avatar
scottyp99
Where do people come up with this stuff?
Scott
Old Jul 13, 2013 | 09:40 PM
  #33
augiedoggy's Avatar
augiedoggy
Scott
I was wondering the same thing.
Old Jul 13, 2013 | 09:41 PM
  #34
augiedoggy's Avatar
augiedoggy
Original block?
Old Jul 13, 2013 | 10:33 PM
  #35
Mike Ward's Avatar
Mike Ward
Scott
Dunno. Also, why do people revive threads that have been dormant for 6 years?
Old Jul 13, 2013 | 10:48 PM
  #36
augiedoggy's Avatar
augiedoggy
I'd say because there is already information in existing threads to build and comment on... it shows people use the "search function " rather than reinvent the wheel all that many times more starting the same threads over and over every other day... It saves time rather than having to rediscover and restate the same facts... its funny how I'll search for a topic here and one thread could totally going the opposite direction and missing important information that another has depending on who seen it and commented.
'Jerry Joe" posted a few fictional facts though.... like the reasons for the .060 gap on his 75 he mentioned in another thread... not sure if someone is feeding him some bad BS or he's making it up?
Old Jul 14, 2013 | 08:21 AM
  #37
7t9l82's Avatar
7t9l82
it keeps old information updated
Old Jul 14, 2013 | 05:20 PM
  #38
aussiejohn's Avatar
aussiejohn
Yeah, but it's the TORQUE that gets the car off the line and as both engines have the same bore and stroke, the torque difference between the two engines is minimal, and therefore the acceleration.
I've got L48 engines in my Vettes, and am quite content with their performance. I drive conservatively so would notice little if any difference if I had an L82.
Regards from Down Under.
aussiejohn
Old Jul 14, 2013 | 08:52 PM
  #39
augiedoggy's Avatar
augiedoggy
aussiejohn
L48 performs better at lower rpms and l82 at higher rpms... both are compromises...
