pivot ball stud won't budge
Old Jul 11, 2007 | 10:52 PM
77vettejeff's Avatar
77vettejeff
Default pivot ball stud won't budge
i'm replacing my clutch and have an adjustable pivot ball stud to install. The old ball stud will not budge. It's been soaking in pb blaster for days. I don't want to go too crazy with force. I have the 90 deg wrench with a foot long pipe and it will not move. Should I try heat? how careful must I be with the aluminum bell housing? Any ideas?
Old Jul 11, 2007 | 11:15 PM
mr303's Avatar
mr303
Heat and then oil quench the threads it will come out no worries!
Old Jul 12, 2007 | 12:04 AM
...Roger...'s Avatar
...Roger...
But I dont think I ever had trouble getting one out.Hmmm turning counter clockwise-Right? I knew you were but just had to ask.
Old Jul 12, 2007 | 01:12 PM
77vettejeff
yes, lol, turning the proper way to loosen. I also looked at the new part to verify it was not a reverse thread. I'll try some heat tonight.
Old Jul 12, 2007 | 03:58 PM
bashcraft's Avatar
bashcraft
Heat the ball stud, not the aluminum, let it cool, it'll come right out. The stud will expand when heated, then shrink when it 's cooled and will be loose.
Old Jul 12, 2007 | 04:18 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
Heat the aluminum with a propane torch<dont worry it wont melt>
Once its good and warm take a candle(unlit) and melt some wax into the thread area. betcha it spins right out.
Aluminum has a faster cooling rate than the steel stud. Thus the bell housing will contract around the stud when it cools. The reason its stuck is because of the dissimilar metals. Try the wax trick it'll work
Old Jul 12, 2007 | 04:24 PM
...Roger...
Never heard of this-sounds interesting-whats happening with the wax?Tell me more.
Old Jul 12, 2007 | 04:34 PM
AzMotorhead
Wow really never heard of it?? It's an old school trick from times before the invent of penetrating lubes.
The parafin wax from the candle is a lubricant it flows really easily when heated and can get into the smallest pores and seams of the threads. It wont dry out and stays in place even after the part has cooled. Its a great trick when removing header or old exhaust manifold bolts.
Also it can be used when drilling through metal or tapping holes
Old Jul 12, 2007 | 04:58 PM
...Roger...
Wow before Liquid Wrench? Dang your older than me!!!
Thanks I will be trying that out-makes sense.I wonder if Sixfooter could have used that trick on his broken thermostat housing bolt?
Old Jul 12, 2007 | 06:41 PM
AzMotorhead
Watch it there Sonny
Actually I just checked your webpage, 35 year GM Tech??
That makes YOU ALOT older than me Ive been working on Jets for 20 years and cars and construction for 10 years before that & I started working at age.... Yep You're older
To pivot ball stud won't budge
