Brake Conversion on a 73
Old Jul 12, 2007 | 11:20 AM
miguel1973's Avatar
miguel1973
Default Brake Conversion on a 73
I was wondering if anyone has put power brakes on a 73 or similar?
If so what is the estimated cost and how difficult was it or did you have a mechanic do the work?
Also any remendations to a nearby shop or where to buy the conversion kit?
Also If you happen to have pics of the process please post.
Thanks everyone.
Old Jul 12, 2007 | 11:45 AM
GunPowder's Avatar
GunPowder
This link may help:
http://forums.corvetteforum.com/show....php?t=1354644 (not a 73 but should be very similar).
Old Jul 12, 2007 | 04:33 PM
Durango_Boy's Avatar
Durango_Boy
Thanks everyone.
Does your car have power steering? If so, it would be an easy install for you to install a hydraulic power brake assist unit that runs off of the power steering system to give you a better than vacuum braking system.
The Hydrobooster mounts where the vacuum booster would go using a custom mounting plate designed to mount a four stud booster to your two bolt firewall.
Then, all you need is a high pressure line going from the pump to the Hydrobooster and a return line going back to the pump. It'll improve your brakes 100% and everything you need can be had for around the same price as a vacuum setup...maybe even cheaper.
Old Jul 12, 2007 | 08:11 PM
miguel1973's Avatar
miguel1973
Thanks guys.
It does have power steering, so maybe I will check going that route.
Any suggestions as to types or brand hydroboosters?
Also do you think a minor skilled mechanic like myself can tackle this job?
Old Jul 12, 2007 | 10:22 PM
Durango_Boy
Thanks guys.
Well, Hydroboosters were made to be installed in all of the big three car maker's cars. They were very popular in GM heavy trucks and for a while they were prevalent in the small vans and mid size cars. Great system.
Yes you can do the install when you consider a lot of guys here have done this swap and there is a lot of information on the process.
To Brake Conversion on a 73
