OOPS, We never seen that in here before..
OK, you probably let the majic smoke out of the fuse links. They can be found connected to the large battery cable connection on the starter. Lift the front and get under there with a light. There is a big cable connected to the starter that comes from the battery, coming off that are 2 smaller wires spliced into other wires. The short pieces are the fuse links, you can get them at Nappa or wherever. Once thats fixed, check the alternator, it might be toast too
