Pistons for 406
Old Jul 12, 2007 | 10:22 PM
myc3's Avatar
myc3
Default Pistons for 406
I am purchasing a 406 rotating assembly and I am having trouble finding forged pistons that will give me over a 10:1 CR. I am using cast iron heads and an OEM block that has not been zero decked. The bore size is 4.155 and I will be using 6" rods.
I want to be at least 10.5 but not over 11.0. So far I have looked at SRP, Federal Mogul and Wiseco. Any suggestions would be greatly appreciated.
Old Jul 12, 2007 | 10:38 PM
LD85's Avatar
LD85
I use Wiseco forged pistons to get 11.1 cr on my 406
Old Jul 12, 2007 | 11:27 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
For the money, Probe forged pistons are great. They'll have the pison you want. Check them out:
http://www.probeindustries.com/Pistons/pistons.htm
Old Jul 12, 2007 | 11:31 PM
jackson's Avatar
jackson
  • How many cc is the combustion chamber of your Iron head?
  • Why do you want at least 10.5:1 scr w/ Iron head 406?
  • What octane fuel will you routinely use?
  • What's this motor's primary purpose? Street, Drag? etc
  • What cam profile?
  • Carb of FI?
Old Jul 13, 2007 | 09:07 AM
myc3's Avatar
myc3
What is the part number? I am using a 64cc combustion chamber, is this what you are using?
Old Jul 13, 2007 | 02:51 PM
myc3's Avatar
myc3
  • What cam profile?
  • Carb of FI?
The combustion chamber is 64cc pocket ported 3927186 camel hump w/ 2.02 - 1.60 valves
I want to go as high as possible with the scr because I intend to upgrade to aluminum heads in the future
I will use 94 octane or if necessary I have access to race fuel
It will be primarily a street motor, may go to track once or twice
Cam is a Lunati 60103 - duration 227 in 233 ex lift 495 in 510 ex
Will be using a reworked Qjet hopefully a Lars rebuild
Old Jul 13, 2007 | 07:57 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
This is VERY similar to an engine that I just finished building (installing this weekend hopefully).
Here's the post where I chose the same cam:
http://forums.corvetteforum.com/show....php?t=1654716
The pistons that I had were stock replacements with a 12.5 cc dish. Based on my calculations, the SCR was 10.1 to 1. With the aluminumb heads, I'm hoping this beast will run on pump gas.
Old Jul 14, 2007 | 12:00 AM
USALT1's Avatar
USALT1
JE SRP
Part#147549 ci=407 bore=4.155 stroke=3.750 rod=6.000 c/r=10.3 w/64cc dome vol= (-)16cc oversize=0.030
Old Jul 14, 2007 | 09:17 AM
Dalannex's Avatar
Dalannex
I found that finding a piston for my 406 with a lower compression ratio (lower being under 10:1) and any longer than stock rod is a very expensive proposition. I ended up going with a 5.7 rod and using a federal mogul powerforged piston but then had to use a 72 cc chamber head to keep the compression down. I am running around 10.25:1 CR on pump gas. My cam specs aren't coming to me right now. (My cam card is in my desk at work)
-Justin
Old Jul 14, 2007 | 09:58 AM
myc3's Avatar
myc3
Originally Posted by USALT1
JE SRP
That is the piston that I was originally planning to use. I found out that the 10.3 was based on a zero deck. My deck has been just cleaned up so it is basically stock. That means the SRP piston is really 9.9 for my application.
I finally found a Wiseco flat top forged piston# PT020H3 that they have listed as 11.4. Their c/r is based on .010 deck height and a .038 gasket. If I then calculate compression using a Felpro 1044 .051 gasket, assume a stock .025 deck height and -5.4 dome volume I get a 10.6 c/r with the Wiseco piston.
That is as high as I want to go.
Old Jul 15, 2007 | 10:32 PM
myc3's Avatar
myc3
xxxx
Old Jul 16, 2007 | 08:45 AM
jimvette999's Avatar
jimvette999
I went with Diamond on my 406 build. They will allow one modification to piston design without a "custom" fee. In my case, I modified the compression height.
http://www.diamondracing.net/products.asp
To Pistons for 406
