rearend noise
Old Jul 14, 2007 | 07:58 AM
70454vette's Avatar
70454vette
Cruising
Default rearend noise
hello
i have a 1970 454 4speed and i have a question. After the car warms up and is on the road for a while, the rear end makes a strange noise in in low rpms and also around turns. its almost like a popping noise. is this the clutch or ?
thanks
Jake
Old Jul 14, 2007 | 08:24 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
When's the last time you changed the rear end fluid. I would do this and be sure to add the posi additive.
Old Jul 14, 2007 | 08:28 AM
70454vette's Avatar
70454vette
Cruising
I actually just purchased the car this past week and was looking for possible solutions
I shall do that though. I do not know if the guy ever did change it.
Old Jul 14, 2007 | 08:39 AM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
That usually solves the problem, and a lot of people actually use 2 bottles of the posi additive. I changed my fluid once not using GM fluid with the posi additive, and I had noise that was not there before; I switched back to GM fluid with the additive and no more noise! I suggest using GM fluid and additive.
Old Jul 14, 2007 | 08:46 AM
Jud Chapin's Avatar
Jud Chapin
It's amazing what the fluid change can do. I had a '67 that chattered on turns and so I changed the fluid. As soon as I backed out of my driveway and made the first turn, all was well.
Old Jul 14, 2007 | 08:48 AM
70454vette's Avatar
70454vette
Cruising
where do i buy the GM fluid at
does it have to be purchased from a GM dealer or online ?
Old Jul 14, 2007 | 08:50 AM
7t2vette's Avatar
7t2vette
You can buy the fluid and additive at any GM dealer parts counter; don't know about online sources.
Old Jul 14, 2007 | 08:55 AM
70454vette's Avatar
70454vette
Cruising
Ill change it today
Thanks alot everyone
This Forum excellent!
Old Jul 14, 2007 | 09:05 AM
kb2fzq's Avatar
kb2fzq
The same story here....took her to Valvoline..$39.99, nice and quiet
Old Jul 14, 2007 | 10:55 AM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Yep.....I used Mobil synthetic 90W with 2 little bottles of the GM additive. Shut my clatter and chatter right UP!
Suck out the old fluid with an old style "pull" suction pump - sold at Autozone for about 12 bucks. Refill through the same side hole til it starts to run out.
To rearend noise
