holley heat shield question
Old Jul 14, 2007 | 12:11 PM
bondoboy's Avatar
bondoboy
Default holley heat shield question
Did anyone here buy the heat shield from holley? It didn't come with any instructions and I was wondering where the gaskets go. There is one thick and one thin one. I wasnt sure if the thick one went under the shield or between the shield and carb. Thanks a lot.
Old Jul 14, 2007 | 03:26 PM
wombvette's Avatar
wombvette
Original applications put the shield next to the carb base with no gasket, but I dont now that they suggest or even what you are using it on.
Old Jul 14, 2007 | 05:13 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
the thick one goes between the intake and the heat shield and the thin one goes between the heat shield and the carb
Old Jul 14, 2007 | 05:16 PM
Tim H's Avatar
Tim H
Now if you didn't need a gasket between the carb and shield then if you didn't use a sheild at all would mean you didn't need a gasket between the carb and the intake either?
Old Jul 14, 2007 | 05:25 PM
bondoboy's Avatar
bondoboy
Thanks for the help.
Old Jul 14, 2007 | 05:39 PM
wombvette's Avatar
wombvette
Well, I cant really say, because I dont know of any application that didnt use a gasket. Just telling how it was on original cast iron manifolds with the exhaust cross over under the carb. They never put a gasket between the carb and the shield.
To holley heat shield question
