So ive been hearing this sea foam stuff is supose to be really good. so i bought a can the only thing is i dont know weather to put it in the gas or oil. which one is supose to work the best? a coulple of my freinds said something bout putting it in the intake? what does that mean? pour it in the carb? im a noob at this sea foam stuff so any info would be great i dont want to blow my engine up or anything.
Thanks!
Don't know about the oil idea--read the directions on the can... just don't drink it. Click and Clack also mentioned its medicinal benefits (my mechanic listens to them as a part of his continuing education program.) When you pour it down the carb, be ready for billowing smoke--used to be a great trick at weddings when carbureters ruled.
just did this a couple of nights ago actually. half can down the carb, and half can in the oil.
it made a ton of smoke, and it may have helped the carb too, but its too early to tell. before i dumped it down my carb, i had some pretty bad hesitation and diesling. aftewards, the hesitation was almost gone and it didnt diesel at all. could have just been a complete coincidence though.
You can add it to your oil too. Just add it as if you were adding oil; through the oil fill cap and not the dipstick tube. I never had the billowing white smoke problem but then again my car is fuel injected with a cat converter. Don't know if that's the reason.
put 1/3 in tank, 1/3 in the crank case
and ran engine for 15 minutes then took the last
1/3 and let it suck in through the brake vacuum connnection
until the engine quit.
let the car sit for 15 more minutes then started it up
and ran it until the smoke stopped.
once that was done i changed the oil and did the
tune up.
it is supposed to decarbon the whole top end when you run
it through the vacuum port and when in the oil it supposed to help
degunk any build up which is why i changed the oil right away.
i dont think i would run it any real length of time with it in
the crank case.
Pouring it down the carb or sucking it through the vacuum port would accomplish the same thing. It would clean your whole top end.
actually no it doesnt, dumping it down the carb doesnt give
you im not even sure if this is right but i guess it would
be called "even dissipation" in the intake to each cylinder.
dumping it down the carb one cylinder may get more than another.
all i did with mine was pull the hose off of the power brake booster
and let it suck the seafoam in through there until the engine quit
and then let it sit for 15 minutes and proceeded as stated in my other post.
be called "even dissipation" in the intake to each cylinder. dumping it down the carb one cylinder may get more than another.
So that would mean air/fuel mixture also travels to one cylinder more than the other? Hmmm
When you dump it down the carb, it should go to each cylinder evenly as though it were the air/fuel mixture itself during each intake stroke.
If it is be sure and change your oil when you are done. it will be shot. If this is for a top end cleaning, I've heard that water...and other products do the same thing. but poor it slowly. If this isn't what the product is used for please let me know.
