Shifty Shifter
Old Oct 31, 2001 | 09:16 AM
TTop Tony's Avatar
TTop Tony
Default Shifty Shifter
The shifter on my 75 is kind of well sloppy is the only way to describe it. I thought about a rebuild for it but would really like the precision of a Hurst. Do they make a Hurst for my super t10? Anyone have any experience with it as far as reliability, ease of install or price? Will rebuilding my stock one give it close to the same feel? What happens to the reverse lockout with the Hurst? As always all opinions are appreciated.
Old Oct 31, 2001 | 10:13 AM
SteveG75's Avatar
SteveG75
Default Re: Shifty Shifter (TTop Tony)
Hurst works great. Be aware that it bolts to transmission vice frame so there is a bit more vibration in the handle. Job took me about 3 hours to do, pulling the transmisison mount for access.
Call Jegs at 1-800-345-4545. They don't list all the apps in the catalog but they have them in stock. Think I paid about $280 for the shifter and instillation kit.
[Modified by SteveG75, 8:13 AM 10/31/2001]
Old Oct 31, 2001 | 10:23 AM
MikeC's Avatar
MikeC
Default Re: Shifty Shifter (SteveG75)
Great upgrade!
There is no reverse lockout on the hurst, other than you have to pull it over to get it into the reverse. I've never accidentally shifted into reverse with it, so it has to work fairly well
Old Oct 31, 2001 | 10:38 AM
Mack's Avatar
Mack
Yep... Works great... No more slush, slush, slush... More like Click, click, click... Not quite, but almost. I think you'll like it. :cool:
Old Oct 31, 2001 | 10:45 AM
TTop Tony's Avatar
TTop Tony
Default Re: Shifty Shifter (Mack76)
Sounds like an overwhelming yes. Now I'm excited. My friends got a 5 speed richmond and he says the worst part is the fact that its bolted to the tranny and vibrates. I've noticed he keeps his hand on the shifter when he's not shifting I don't do that so maybe the vibration won't bother me. Still it sounds like the HURST is worth it. Thanks guys.
Old Oct 31, 2001 | 07:22 PM
bud snyder's Avatar
bud snyder
Tony,
You can add the stock looking handle from Ecklers if you want that stock look.
Old Oct 31, 2001 | 07:36 PM
bence13_33's Avatar
bence13_33
Default Re: Shifty Shifter (MikeC)
There's no reverse lock-out? That's kind of a bummer, it's nice to have that little extra security when shifting....
Old Nov 1, 2001 | 02:21 AM
SteveG75's Avatar
SteveG75
Default Re: Shifty Shifter (bence13_33)
Shifter is springloaded to 3-4 gates. There is quite a bump (best way to describe) to get it in R instead of 1-2. I don't think that there is anyone here who would select R instead of 1 by accident.
Old Nov 1, 2001 | 08:07 AM
glen242's Avatar
glen242
Tony:
Before you spring for the Hurst, check and see if the shifter arms on the transmission have 2 sets of holes. If so, relocate the rods to the lower holes. This will tighten the shift pattern and cut down on the slop, but will require more effort to shift. Did this on my '76 with no problems. If you don't like it, you can always go back to stock and/or add the Hurst.
Old Nov 1, 2001 | 08:56 AM
TTop Tony's Avatar
TTop Tony
Default Re: Shifty Shifter (glen242)
There are two holes I did notice that. I see where that would give me less of a throw but how does that "tighten" it. Your right though that would would be free to try.
I'm worried about the reverse lockout too. This is my first stick shift car. I have a constant fear of being in the wrong gear But if its spring loaded and the car is a lot more "notchy" then mine maybe it won't be so bad.
Old Nov 1, 2001 | 08:21 PM
glen242's Avatar
glen242
Tony:
Using the lower holes reduces the distance that the shift lever moves when going between gears. Every shift i.e. 1-2, 2-3, 3-4 has about 1/2 the shifter travel as when the top holes are used.
Try it, it don't cost nothin!
Old Nov 2, 2001 | 09:09 AM
TTop Tony's Avatar
TTop Tony
I will try it. At worst if I don't like it I can always get the HURST.
To Shifty Shifter
