Fuel Problem
Old Jul 16, 2007 | 07:35 PM
Doug Maitlen's Avatar
Doug Maitlen
Default Fuel Problem
On my 79, a fuel line runs up the passenger side chassis and under the engine into some type of canister. What is this object and what should I do about it leaking?
Old Jul 16, 2007 | 07:57 PM
Red 69's Avatar
Red 69
If the cannister is silver, you are probably looking at the fuel pump. There are two lines, one a feed and the smaller line a return to the tank. Both lines are connected to the fuel pump with a rubber hose. First, find if the leak is coming from the hose or pump. It could be you need to replace 28 year old hose, or just tighten a bolt. Be very careful around raw fuel and have an extinguisher handy.
