hp difference
Old Jul 16, 2007 | 07:58 PM
glo's Avatar
glo
Default hp difference
doing a rebulid have the following:
383stroker
6in rods
2 valve relief flat top piston
750 holley
headers
882 heads 76cc 1.96/1.5
any idea what hp would be with this setup and what would hp be with 64 cc 2.02/1.6 head.
Old Jul 16, 2007 | 08:07 PM
Gordonm's Avatar
Gordonm
Not enough info. Need cam and what comp ratio with these heads.
Those heads are going to severly reduce your HP on a 383 setup.
Old Jul 16, 2007 | 08:10 PM
gerry72's Avatar
gerry72
The cam component is missing out of this. Cam and heads are going to be where most of the power is made. 882 heads are stinkers and will be your primary limitation.
And anyone guessing on power is doing just that...guessing. How much power you can make depends upon how savvy a tuner you are. Many excellent combinations don't achieve anywhere near their potential due to tuning errors. And many not so well matched combinations do better than expected due to some excellent tuning.
Old Jul 17, 2007 | 05:25 AM
glo's Avatar
glo
Default cam info
sorry the cam is
duration 244 / 224
lift 450
advert.292 / 288
To hp difference
