Rear gears selection help needed.
Old Oct 31, 2001 | 02:17 PM
John Dirks's Avatar
John Dirks
Default Rear gears selection help needed.
I have a well built 383, TH350 with shift kit, 2500 stall, Edlbro performer RPM, Edlbro 750 carb, MSD, Headers, Dual exhaust, Flowmasters etc...
Unfortunately I have 3.08 gears.
I want advice on two things.
1. What gears should I get that will really work well on the street, strip, and occasional highway cruise?
2. What sticky tires should I consider buying? I currently only have BFG TA's.
Old Oct 31, 2001 | 03:05 PM
The Dude's Avatar
The Dude
Default Re: Rear gears selection help needed. (John Dirks)
1. 3.55s are about the best all-around rear end gears for a 'Vette with a TH 350.
2. I think you're fine with T/As on the street. Goodrich also makes some pretty decent drag radials for the track.
Old Oct 31, 2001 | 03:10 PM
Neo Fender's Avatar
Neo Fender
How about a TH 700 instead?
Old Oct 31, 2001 | 03:35 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
If your going to see some occasional highway, I wouldn't go above 3.70's unless you plan on a O/D in the future. I love my 3.90's and won't be changing them, but will be installing a O/D to be able to drive for longer distances.
Old Oct 31, 2001 | 03:48 PM
Wrencher's Avatar
Wrencher
Default Re: Rear gears selection help needed. (mikeo)
I'm with Mikeo on this. I have 3.55's, but would use 3.70's for street/strip use.
Hans
Old Oct 31, 2001 | 04:46 PM
norvalwilhelm's Avatar
norvalwilhelm
Without overdrive stay with 3.55. The 3.70 will make the car a dog on the expressways, about 3500 at normal cruiseing. I like the idea of a 700-R4.
Old Oct 31, 2001 | 06:49 PM
John Dirks's Avatar
John Dirks
Default Re: Rear gears selection help needed. (norvalwilhelm)
What would the RPM be at 60 MPH with 3.55 and what would they be with 3.73
Old Oct 31, 2001 | 07:10 PM
bence13_33's Avatar
bence13_33
John:
To answer your last question, http://www.smokemup.com has an RPM calculator that does exactly what you were asking about. To figure out your RPMs you will need to know the gear ratios in your transmission, tire height and rear gear. It's a very useful site! Enjoy :cool:
Old Oct 31, 2001 | 07:14 PM
bud snyder's Avatar
bud snyder
John,
You can go to Richmond Gear and use their calculators to get the information you want.
As for the gears, 3:55 for highway, 3:70 for around town, 3:90 for all out performance.
Bud
Old Nov 1, 2001 | 01:55 PM
John Dirks's Avatar
John Dirks
Default Re: Rear gears selection help needed. (bud snyder)
3.55 for Highway, and 3.73 for street strip.
Does everyone agree with this?
Old Nov 1, 2001 | 02:05 PM
KJL's Avatar
KJL
I have thought about doing same with my TB400. Is changing rear gears something for the home mechanic, or is this best left to the pro's? The way people talk about changing gears it sounds it should be as easy as changing your pants!!! :crazy:
Old Nov 1, 2001 | 02:42 PM
John Dirks's Avatar
John Dirks
Default Re: Rear gears selection help needed. (KJL)
Any thoughts on what make of gears I should go with?
Old Nov 1, 2001 | 02:46 PM
81vette's Avatar
81vette
Here's my suggestion:
2.72 to 3.08 for highway.
3.73 to 4.11 for street/strip.
3.42 for all around.
Old Nov 1, 2001 | 05:48 PM
79Corvette02's Avatar
79Corvette02
Well, I have 4.11 gears out back, and its a blast-especially when coming out of a turn or from a dead stop. W/ the TH-350 trans. 1st gear, its a real hoot. although w/ its 1.00:1 third gear, the highway is a friggin' nightmare. You really have to decide. I'd say 3.73's are a good compromise. :seeya
Old Nov 1, 2001 | 07:23 PM
John Dirks's Avatar
John Dirks
Default Re: Rear gears selection help needed. (79Corvette02)
Most votes are for 3.73
Any other thoughts?
Old Nov 1, 2001 | 08:23 PM
nastee383's Avatar
nastee383
For street/strip a 700R4, 3:70's and drag radials for racing is the setup. I've pulled a 1.54 and a 1.55 60' AND get 15 mixed and 21 hwy mpg with a Q-Jet. And if you get lazy after racing you can drive around town with the Drag Radials on until you feel up to changing them again. Just don't get caught in the rain!
Old Nov 1, 2001 | 11:32 PM
John Dirks's Avatar
John Dirks
Default Re: Rear gears selection help needed. (nastee383)
Nastee, what tranny did you have before the 700R4?
Did you buy a new 700 or used?
Did you do the swap?
How hard was the swap, and what changes were needed?
To Rear gears selection help needed.
Old Nov 1, 2001 | 11:54 PM
Stingy74's Avatar
Stingy74
Default rear gears
I have 4.11's with a 700 and it revs about 2400 at 60mph. Reved 1900 with 3.08's and I think 2100 or so with the 3.55's. By far the 4.11's was the best choice I ever made but also the worst choice I ever made. It all boils down to the 700-R4. The 1st gear and 4.11 combo was too much for autocrossing. I could never get enough speed out of it and when I shifted to secong I lost all the grunt and response and ended up going to fast. Also, first gear was unusable on the street. For showing off to friends only. If I were to do it all over again it would be 4.56's and a TH350. I'll save the highway driving for my Riviera.
Old Nov 2, 2001 | 12:43 AM
flynhi's Avatar
flynhi
I'm no expert on this but it seems to me that you should analyze final drive ratios along with your torque curve to determine what will work for you.
My experience has been that a first gear final drive ratio (first gear multiplied times rear end ratio) of about 9.25 works well with a medium-high HP vette to get out of the hole without losing traction. For second and third, select a final ratio that puts your RPM right in the middle of your torque curve at speeds you normally drive. For fourth or final gear ratio, lower final drive ratio will save your engine and use less gas.
Run the numbers with several different combos before changing and get it right the first time.
Old Nov 2, 2001 | 08:21 PM
nastee383's Avatar
nastee383
It had the original TH400. I had a local transmission shop build the trans and converter and do the swap so I can't really give you alot of details. I was very wary initially and thought the trans would be the first thing to go when I started racing but it has lasted over 3 years with no problems at all. He wasn't very specific about what he did but he swore to me it would be built as strong as one could be built. It probably doesn't hurt that I use a deep pan, a cooler (not thru the radiator), the stall is only 2000 and the temp is @ 110 -130 degrees normally.
