Buying shop press....
Old Jul 17, 2007 | 11:08 AM
Talisman51's Avatar
Talisman51
Default Buying shop press....
Looking for capacity and spec recommendation on buying a economical shop press for typical automotive needs....ie...bearing races, bushings, water pumps...
What pressures are needed (6, 12, 20 ton)? What styles...H-press, A-press, C-press? Bench mount vs floor?
Old Jul 17, 2007 | 11:42 AM
mayberg's Avatar
mayberg
If you've ever observed someone trying to remove the bearings from the rear spindle, then you know that more is better. I say get a floor mounted H-frame 20 ton as a minimum.
My philosophy of life - it's better to have it and not need it, then to need it and not have it.
Old Jul 17, 2007 | 01:20 PM
Vette Gator's Avatar
Vette Gator
I checked out the shop presses at Harbor Freight a couple of months ago with the idea of getting a 10- or 20-ton model. There was too much play in the ram for my taste, so I decided to pass. I had no trouble with the rear bearing rebuild using a medium-sized arbor press where I work. I'm not sure exactly what pressure it's rated at, but it's very accurate in driving the post down squarely with virtually no chance of side-to-side movement. The only job that taxed the arbor press was punching out the old U-joints from the drive- and half-shafts. Knowing what I do now, I should have used a torch to cut the crosses out before pushing out the bearing caps. That would have been no problem for the arbor press. If I didn't have easy access to one at work, I would buy an arbor press for home use.
Old Jul 17, 2007 | 01:26 PM
SIXFOOTER's Avatar
SIXFOOTER
I got a 12T HF press, H-Frame style. It has done bearings, races, bushings, bent and straightned steel parts, no problem. If you have floor space available get the biggest one you can afford
Old Jul 17, 2007 | 01:46 PM
yukon988's Avatar
yukon988
I had the 20 ton HF press and used it for all kinds of stuff. It worked great for me but other people have told me that the rams do not last long. They don't take up that much space either.
Old Jul 17, 2007 | 02:06 PM
Talisman51's Avatar
Talisman51
Default Choices..choices..choices....
Thank guys!. Being space impaired ,I would love an arbor press....but.... I am hoping to rebuild some water pumps and I don't think I can get a deep enough or tall enough working space with the arbors I have seen. There are many very affordable Chinese options on-line. Both Greg Smith and ASEdeals offer inexpensive options even below HF prices....$139 for a 20T H press. I just hate spending good money on junk...especially heavy junk....
Old Jul 17, 2007 | 03:21 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Same one I have. For the cost difference, I couldn't justify the 20-ton model. I used it to install my 1/2" wheel studs on all four hubs, straighten parts, and re-assemble my T/As after Gary set them up for me. It hasn't let me down yet.
If the ram goes out, go to the auto parts store and buy a new bottle jack. That's all it is.
Old Jul 17, 2007 | 04:06 PM
SIXFOOTER's Avatar
SIXFOOTER
Yep
Old Jul 17, 2007 | 04:10 PM
Talisman51's Avatar
Talisman51
Default Suppose 12 Ton is plenty....unless
Going up to the 20 ton will probably just allow me to break stuff easier.....right? Sounds like I can save a few bucks and still get the job done with the 12 ton. I checked out the Torin Big Red 20 ton (made in china) over at the local Pep Boys this afternoon. At 200 lbs it looks like a mule of a press. However, I am a bit concerned with a the very short ram protruding from the bottom of the press. The good news is the units are ANSI certified....this gives me some sense of quality assurance. The Torin's also carry a one year warranty.
Old Jul 17, 2007 | 07:52 PM
Goobzilla's Avatar
Goobzilla
Another owner of the 12 ton HF press here. I've done several rear end rebuilds with it and it's held up just fine.
Old Jul 17, 2007 | 09:03 PM
Green73's Avatar
Green73
If I were to buy one I'd seriously look at the harbor frieght model, esp. since your not going to be making your living with the tool. I have many handy tools that I'd use occasonally from there and have never had a problem. With this only being a couple of pieces of steel, two springs and a bottle jack, I don't really see how the chinese could screw this up. Don't know what anyone would need a 20 ton press for either... 12 ton seems like more than enough. Just my .02...
Old Jul 17, 2007 | 09:49 PM
speedreed8's Avatar
speedreed8
12 ton hf also, rebuilt the front suspension with it, a arm bushings etc.
worked great, $50 off of ebay. picked up locally.
To Buying shop press....
