simple quick question
Old Jul 17, 2007 | 08:18 PM
jamesd2's Avatar
jamesd2
Default simple quick question
'73 has minor backfiring after medium strong accelleration. Too rich? If so, how much do i lean it out (q-jet 4mw) in terms of turns? thanks in advance......
Old Jul 17, 2007 | 09:03 PM
ecorse66's Avatar
ecorse66
Does your Vette still have the A.I.R. pump hooked up? If so check the diverter valve. It looks like a small engine muffler as I recall and the A.I. R. hoses attach to it. When these go bad you get exactly the backfire you describe. Mine went out on my '74 when it was less then 2 yrs. old. Adjusting the idle screws on the carb will only affect mixture at idle. To lean or richen the carb you have to change jets.
Dave T.
Old Jul 18, 2007 | 07:38 PM
jamesd2's Avatar
jamesd2
ecorse........A.I.R pump not present, car backfires after gas pedal is released. Anyone else?
Old Jul 18, 2007 | 10:35 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
When you use the term backfire, do you mean back thru the carb or in the pipes? Just wanting to clarify that, since many people use the same word for both, and it makes a difference as to what may be going on...
Old Jul 18, 2007 | 10:41 PM
jamesd2's Avatar
jamesd2
skunkworks - backfire is clearly in sidepipes..........
Old Jul 19, 2007 | 12:43 AM
TheSkunkWorks
OK, I'll go to one of my favorite Larsisms: 90% of all carb problems are ignition problems.
Make sure that's all good before we move to blaming the carb. Need to check the entire timing curve w/o vac adv attached and see where you are.
To simple quick question
