Cam Timing
Old Jul 18, 2007 | 07:32 AM
mrhurk's Avatar
mrhurk
Default Cam Timing
I have the Cam and Crank gears lined up with the dots facing each other. I know this means #1 cylinder is at TDC. IS #1 pistion at TDC on the firing or exhaust stroke?
Dean
Old Jul 18, 2007 | 07:54 AM
73VetteKS's Avatar
73VetteKS
I think it is TDC firing, but you can easily verify that by rotating the crank and watching the valves.
Old Jul 18, 2007 | 08:32 AM
stingr69's Avatar
stingr69
Dean
Dots together = #1 and #6 are both at TDC. #6 is TDC firing position and #1 is at TDC exhaust position.
-Mark.
Old Jul 18, 2007 | 09:24 AM
Tim H's Avatar
Tim H
I think all you have to do is , add the balencer and turn it 180 degrees and it will line up the zero and the timing tab and that will be #1 TDC and ready to drop the dist in on the #1 plug wire.
I just did this about 2 weeks ago.
Old Jul 18, 2007 | 09:36 AM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Me too......and ......... .
Old Jul 18, 2007 | 10:09 AM
sxr6's Avatar
sxr6
Dot to Dot & drop dizzy in #6 position, saves one step
Old Jul 18, 2007 | 11:18 AM
akfox1's Avatar
akfox1
Default Big block too?
Hey guys, does this rule work for big blocks also? Seems like it would.
Old Jul 18, 2007 | 02:54 PM
stingr69's Avatar
stingr69
Close but no cigar for you!
Rotate the crank 360 degrees (not 180 degrees) and drop in the distributor so it points to #1. Then you are good to go.
-Mark.
Old Jul 18, 2007 | 04:44 PM
fotyfobravo
-Mark.
YOU'RE RIGHT ! 360 - one full turn .... 180 would only be a half !
To Cam Timing
