Engine Block Arrived Today!
Old Oct 31, 2001 | 07:33 PM
bence13_33's Avatar
bence13_33
Default Engine Block Arrived Today!
I finally have a 454 block that I can use (the other one had two cracked cylinder walls). I was surprised to see Hi-Perf Pass stamped on the block, this block was from the '80s I believe. I wasn't aware that there were any high performance passenger cars in the 80s ;). I examined the cylinder walls...no cracks but it does have a slight ridge so I will be having it bored +.030 as planned. It only has 2 bolt mains but hey, I'm just glad I could finally get a hold of a 454 block. I picked the engine up for $350 shipped to my house, which was a heck of a lot cheaper than anyone around my area was asking for a 454 block.
Piece by piece I'm nearing my goal. I can't wait until I start assembling it :) My 3.70 rear end should be coming in about a week or two from now also :D
Old Oct 31, 2001 | 07:36 PM
QuickVet's Avatar
QuickVet
Default Re: Engine Block Arrived Today! (bence13_33)
cool, it all coming together now! pics please.
[Modified by Vetteboy, 6:36 PM 10/31/2001]
Old Oct 31, 2001 | 08:05 PM
nunus79's Avatar
nunus79
You gotta get a few track runs with that 3.70 rear with your existing setup. I remember doing some number crunching for you months ago. You had a pretty good existing setup w/3.70s. I think low 14s. Anyway, it'll make a good baseline for you when you get the monster installed. Good luck as always!
Old Oct 31, 2001 | 08:15 PM
rob75383's Avatar
rob75383
Bence, I recall from many months ago you had mangled your rear end.
Did you exchange this, or just buy a whole new setup??
If you did exchange, how much did they deduct from you??
Can you refresh my memory... I think you had a busted ring& pinion, but didn't you crack the case too??
Who did you wind up getting it from??
Old Oct 31, 2001 | 08:30 PM
bence13_33's Avatar
bence13_33
Default Re: Engine Block Arrived Today! ('75 383 ElkGrove)
Yea the rear end was toast. I twisted the posi case in two, exploded the posi packs, snapped 3 teeth off of the ring gear and 2 teeth off of the pinion gear. The case however was in perfect shape. I didn't exchange the rear end....there's basically nothing ot exchange :). I have the case and exploded parts sitting up in my garage to show all of my friends. I purchased the rear end off of a fellow forum member. The rear end is freshly rebuilt so it's ready to be bolted in.
Old Oct 31, 2001 | 08:33 PM
rob75383's Avatar
rob75383
For the future, I think if I get some extra $$$, I'll pick up a 4.11 rear, and that way I can swap the rear from 3.70 to 4.11.
Chances are, though, I'll just fall in love with the 4.11, and just keep it in there full time.
Bence, which side yokes did you go with??
Old Oct 31, 2001 | 08:37 PM
bence13_33's Avatar
bence13_33
I'm still running my stock yokes, the HD yokes are a little out of my price range. I wanted to go with the 4.11 rear end but I'm afraid that it would be too much gear for me. The 3.70s will be bad enough on the highway let alone a 4.11. If I didn't drive my car so much, I would have gotten a 4.11 rear end.
[Modified by bence13_33, 6:39 PM 10/31/2001]
Old Oct 31, 2001 | 09:00 PM
ZD75blue's Avatar
ZD75blue
ooohhh its getting close... you can almost feel the rumble through the open headers... its that head ache coming on :jester
Bence glad to hear that your project is getting closer to finshed, and your having fun in the process
ZD :cheers:
To Engine Block Arrived Today!
