bellhousing repair
Old Jul 19, 2007 | 04:08 PM
James B's Avatar
James B
Default bellhousing repair
I was wondering what it would take to repair this crack. If I did have this fixed would it compromise its strength? It would probably only cost 10 bucks to pay someone to weld it.
Old Jul 19, 2007 | 04:11 PM
GaryS's Avatar
GaryS
The only place that I would trust an original aluminum housing too for a perfect repair is Jerry MacNeish of Camaro Hi-Performance, Inc.
http://www.z28camaro.com/
Review the site for examples of his work.
Old Jul 19, 2007 | 05:45 PM
James B's Avatar
James B
I was kind of hoping to have the work done locally. Will that crack affect the strength of the bellhousing?
Old Jul 19, 2007 | 05:51 PM
gerry72's Avatar
gerry72
Take it to any machine shop for TIG welding. Aluminum is one of the easiest metals to repair and the weld will easily exceed the strength of the parent metal.
Old Jul 19, 2007 | 07:20 PM
mdbelanger's Avatar
mdbelanger
Check out some boat yards they weld Alum almost every day.
Old Jul 19, 2007 | 08:49 PM
stingr69's Avatar
stingr69
I would just get a different one. Replacements are not too hard to find and the repair will cost more than you think. Once it is welded the bellhousing will likely be heat warped. I had one heli-arc'd and it was trash once it was finished. Not worth the effort unless it only needs minimal work.
-Mark.
Old Jul 19, 2007 | 09:20 PM
Gordonm's Avatar
Gordonm
I had mine tigged up for a crack tha twas right at the bottom. It was about a 4 inch crack. after tigging and a little grinder work you could not tell it was welded. Just as strong as the rest of the bellhousing. Never had any problems while putting 400HP through it. I had it done for free. A friend owed me a favor. Should not cost that much anyway.
Old Jul 19, 2007 | 09:38 PM
James B's Avatar
James B
Dangit! I was going to bid on it on ebay but with 2 minutes left my computer froze....go figure. It went for 118 + 20 bucks to ship. Ill just get a repo for 150.
Thanks for the information guys!
To bellhousing repair
