A couple questions on engine HP
.50-226. Exhaust @ .50-226. Intake Lift .500. Exhaust Lift .500. TorkerII Intake: Recurved HEI. Match Ports, and header side-pipes. TH 350 Stage II Shift Kit: 2000 stall TC. The machinist/engine builder told me that this combination would produce 425-450 HP. This motor pulls real strong from mid-range on, but lacks a lot at the low end. How much help on the low end would I gain by changing the rear end? I'm now running 307 gears. Oh, and I almost forgot...I used my old, Q-jet, after doing a lot of major overhaul to include multiple attempts at getting the correct jet size.
If you want to keep the Q-Jet, get an Edelbrock Performer RPM Q-Jet 7104. Ignore what Edelbrock says about fit. Fits just fine on my '75 with a Moroso low profile aircleaner and 3" filter. I just had to dmple the base a little for the accelerator pump arm.
Different gears will not help the low end, they will just get the engine up into the higher RPM band faster.
As for HP estimates, which heads are you using. Stock '76 heads will choke the engine even with 2.02/1.60 valves. Probably closer to 375 hp with the stock heads. AFR heads are top of the line, maybe 425 hp, maybe. 450 hp, no way.
Obviously, hood clearance will dictate what you could use.
Another suggestion for your low end woes.... you could try a higher stall speed... eg 2800~3000 rpm. This will get the motor into the mid-range sooner, so you can maximise accelleration. OK for dedicated strip cars... but driveability (and fuel consumption) would suffer on the road.
The diff gears are still a concern though. Obviously a ratio like 3.7 will definitely improve torque availability, but once again, rpm at cruising speeds will elevate... increasing moise level, fuel consumption and engine wear.
What do you realistically want to use the car for.... If its for all out performance, choose a diff ratio which will see you crossing the quarter mile near to your max rpm. That way you will get the most benefit out of diff gearing for accelleration.
Engine power ??? who knows. I'd put it on the chassis dyno after installation to know how many REAL neddies you have.
Claimed engine power and real rear wheel power are completely different
Auto trans suck up a lot of power. I'm considering a swap to a manual trans for this very reason.
cheers
tom
